Create a Duo profile
Creates a Duo profile to manage authentication processes within your ONTAP environment. This is typically used to configure multi-factor authentication settings.
HTTP method and endpoint
POST /security/authentication/duo/profiles
Introduced in
ONTAP 9.14
Required properties
api_host- Duo API host -
integration_key- Integration key -
secret_key- Secret key
Related ONTAP commands
security login duo create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
api_host |
string |
The URL at which the Duo API is hosted. |
auto_push |
boolean |
Automatically sends a push notification for authentication when using Duo. |
comment |
string |
Comment for the Duo profile. |
fail_mode |
string |
Determines the behavior of the system when it cannot communicate with the Duo service. |
fingerprint |
string |
The SHA fingerprint corresponding to the Duo secret key. |
http_proxy |
string |
Specifies the HTTP proxy server to be used when connecting to the Duo service. |
integration_key |
string |
The Integration Key associated with the Duo profile. |
is_enabled |
boolean |
Indicates whether the Duo authentication feature is active or inactive. |
max_prompts |
integer |
The maximum number of authentication attempts allowed for a user before the process is terminated. |
owner |
SVM name and UUID for which the Duo profile is configured. |
push_info |
boolean |
Additional information sent along with the push notification for Duo authentication. |
secret_key |
string |
The Secret Key associated with the Duo profile. |
status |
string |
Information on the reachability status of Duo. |
Example request
"api_host": "api-****.duo.com",
"auto_push": 1,
"comment": "string",
"fail_mode": "safe",
"fingerprint": "string",
"http_proxy": "IPaddress:port",
"integration_key": "string",
"is_enabled": 1,
"max_prompts": 1,
"owner": {
"name": "svm1",
"push_info": 1,
"secret_key": "string",
"status": "OK"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[duo] |
"num_records": 1,
"records": [
"auto_push": 1,
"is_enabled": 1,
"max_prompts": 1,
"owner": {
"name": "svm1",
"push_info": 1,
"status": "OK"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default, Error
href |
string |
_links
owner
name |
string |
uuid |
string |
duo
Duo profile for the SVM or cluster-management server (Cserver).
api_host |
string |
auto_push |
boolean |
comment |
string |
fail_mode |
string |
fingerprint |
string |
http_proxy |
string |
integration_key |
string |
is_enabled |
boolean |
max_prompts |
integer |
owner |
push_info |
boolean |
secret_key |
string |
status |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
