REST API reference
Create a multi-admin-verify approval group
Creates a multi-admin-verify approval group to manage and verify administrative actions that require multiple approvals. This is useful for enforcing security policies and ensuring compliance in your administrative workflows.
HTTP method and endpoint
POST /security/multi-admin-verify/approval-groups
Introduced in
ONTAP 9.11
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
approvers
array[string]
List of users that can approve a request.
email
array[string]
Email addresses that are notified when a request is created, approved, vetoed, or executed.
name
string
Name of the approval group.
owner
owner
The owner of the approval group. The only valid owner is currently the cluster.
Example request
  "approvers": [
    "string"
  "email": [
    "string"
  "name": "string",
  "owner": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[multi_admin_verify_approval_group]
  "num_records": 1,
  "records": [
      "approvers": [
        "string"
      "email": [
        "string"
      "name": "string",
      "owner": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262309
The feature must be enabled first.
262333
Invalid user in approval group.
string
owner
name
string
The name of the SVM. This field cannot be specified in a POST or PATCH method.
uuid
string
approvers
array[string]
email
array[string]
name
string
owner
owner
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
