Create an NVMe namespace
POST /storage/namespaces
Introduced In: 9.6
Creates an NVMe namespace.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the NVMe namespace. -
name,location.volume.nameorlocation.volume.uuid- Existing volume in which to create the NVMe namespace. -
nameorlocation.namespace- Base name for the NVMe namespace. -
os_type- Operating system from which the NVMe namespace will be accessed. (Not used for clones, which are created based on theos_typeof the source NVMe namespace.) -
space.size- Size for the NVMe namespace. (Not used for clones, which are created based on the size of the source NVMe namespace.)
Default property values
If not specified in POST, the following default property values are assigned:
auto_delete- false -
space.block_size- 4096 ( 512 when 'os_type' is vmware )
Related ONTAP commands
volume file clone autodelete -
volume file clone create -
vserver nvme namespace convert-from-lun -
vserver nvme namespace create
POST is asynchronous when creating a new namespace. It is synchronous when converting a LUN to a namespace via the convert property.
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
auto_delete |
boolean |
This property marks the NVMe namespace for auto deletion when the volume containing the namespace runs out of space. This is most commonly set on namespace clones. When set to true, the NVMe namespace becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the namespace is also configured for auto deletion and free space in the volume decreases below a particular threshold. This property is optional in POST and PATCH. The default value for a new NVMe namespace is false. There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the |
clone |
This sub-object is used in POST to create a new NVMe namespace as a clone of an existing namespace, or PATCH to overwrite an existing namespace as a clone of another. Setting a property in this sub-object indicates that a namespace clone is desired. When used in a PATCH, the patched NVMe namespace's data is over-written as a clone of the source and the following properties are preserved from the patched namespace unless otherwise specified as part of the PATCH: |
comment |
string |
A configurable comment available for use by the administrator. Valid in POST and PATCH. |
consistency_group |
The namespace's consistency group. This property is populated for namespaces that are members of a consistency group. If the namespace is a member of a child consistency group, the parent consistency group is reported. A namespace's consistency group is the consistency group of its containing volume. |
convert |
This sub-object is used in POST to convert a valid in-place LUN to an NVMe namespace. Setting a property in this sub-object indicates that a conversion from the specified LUN to NVMe namespace is desired. |
create_time |
string |
The time the NVMe namespace was created. |
enabled |
boolean |
The enabled state of the NVMe namespace. Certain error conditions cause the namespace to become disabled. If the namespace is disabled, check the |
location |
The location of the NVMe namespace within the ONTAP cluster. NVMe namespaces do not support rename, or movement between volumes. Valid in POST.
name |
string |
The name of the NVMe namespace. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume. NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. Renaming an NVMe namespace is not supported. Valid in POST. |
os_type |
string |
The operating system type of the NVMe namespace. Required in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone. |
provisioning_options |
Options that are applied to the operation. |
space |
The storage space related properties of the NVMe namespace. |
status |
Status information about the NVMe namespace. |
subsystem_map |
The NVMe subsystem with which the NVMe namespace is associated. A namespace can be mapped to zero (0) or one (1) subsystems. There is an added computational cost to retrieving property values for |
svm |
uuid |
string |
The unique identifier of the NVMe namespace. |
Example request
"clone": {
"source": {
"name": "/vol/volume1/namespace1",
"comment": "string",
"consistency_group": {
"name": "cg1",
"uuid": "4abc2317-4332-9d37-93a0-20bd29c22df0"
"convert": {
"lun": {
"name": "/vol/volume1/lun1",
"create_time": "2018-06-04 15:00:00 -0400",
"location": {
"namespace": "namespace1",
"node": {
"name": "node1",
"qtree": {
"id": 1,
"name": "qt1"
"volume": {
"name": "volume1",
"name": "/vol/volume1/qtree1/namespace1",
"os_type": "string",
"provisioning_options": {
"qos_policy": {
"name": "performance",
"snapshot_policy": {
"name": "default",
"storage_service": {
"name": "string"
"tiering": {
"control": "string",
"object_stores": [
"name": "string"
"policy": "string"
"space": {
"block_size": 512,
"efficiency_ratio": 2.5,
"physical_used": 1073741824,
"physical_used_by_snapshots": 1073741824,
"size": 1073741824,
"used": 0
"status": {
"container_state": "string",
"state": "online"
"subsystem_map": {
"anagrpid": "00103050h",
"nsid": "00000001h",
"subsystem": {
"hosts": [
"dh_hmac_chap": {
"controller_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
"group_size": "string",
"hash_function": "string",
"host_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
"mode": "bidirectional"
"nqn": "nqn.1992-01.example.com:string",
"priority": "string",
"tls": {
"configured_psk": "NVMeTLSkey-1:01:VRLbtnN9AQb2WXW3c9+wEf/DRLz0QuLdbYvEhwtdWwNf9LrZ:",
"key_type": "configured"
"name": "subsystem1",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
917927 |
The specified volume was not found. |
918236 |
The specified |
1254197 |
The LUN specified for conversion to a namespace is mapped. |
1260121 |
Cloning a namespace to a volume different than the source volume is not supported. |
1260136 |
The specified destination for a clone operation already exists as a LUN, namespace, or file. |
2621462 |
The supplied SVM does not exist. |
2621706 |
The specified |
2621707 |
No SVM was specified. Either |
5242927 |
The specified qtree was not found. |
5242950 |
The specified |
5374127 |
The specified namespace name is invalid. |
5374140 |
LUN has a non-zero prefix and/or suffix size. |
5374141 |
LUN is part of a SnapMirror active sync relationship. |
5374156 |
A protocol endpoint LUN cannot be converted to an NVMe namespace. |
5374157 |
LUN in an SVM with MetroCluster configured cannot be converted to an NVMe namespace. |
5374158 |
LUN contains an operating system type that is not supported for NVMe namespace. |
5374352 |
An invalid name was provided for the NVMe namespace. |
5374858 |
The volume specified by |
5374860 |
The qtree specified by |
5374861 |
The NVME namespace base name specified by |
5374862 |
No NVMe namespace path base name was provided for the namespace. |
5374876 |
The LUN specified for conversion to a namespace was not found. |
5376461 |
5376462 |
The specified namespace name is too long. |
5376463 |
The snapshot portion of the specified namespace name is too long. |
5440509 |
No suitable storage can be found for the specified requirements. |
13565952 |
The NVMe namespace clone request failed. |
72089636 |
Creating NVMe namespaces with |
72089720 |
NVMe namespaces cannot be created in snapshots. |
72089721 |
The volume specified is in a load sharing mirror relationship. Namespaces are not supported in load sharing mirrors. |
72089722 |
A negative size was provided for the NVMe namespace. |
72089723 |
The specified size is too small for the NVMe namespace. |
72089724 |
The specified size is too large for the NVMe namespace. |
72089725 |
A LUN or NVMe namespace already exists at the specified path. |
72089727 |
NVMe namespaces cannot be created on an SVM root volume. |
72089728 |
NVMe namespaces cannot be created on a FlexGroup volume. |
72089732 |
An NVMe namespace name can only contain characters A-Z, a-z, 0-9, "-", ".", "_", "{" and "}". |
72090005 |
The specified |
72090006 |
The specified |
72090007 |
The specified |
72090009 |
An error occurred after successfully creating the NVMe namespace. Some properties were not set. |
72090012 |
The property cannot be specified when creating an NVMe namespace clone. The |
72090013 |
The property is required except when creating an NVMe namespace clone. The |
72090014 |
No volume was specified for the NVMe namespace. |
72090015 |
An error occurred after successfully creating the NVMe namespace preventing the retrieval of its properties. |
72090033 |
The |
72090039 |
The property cannot be specified at the same time when creating an NVMe namespace as a clone. The |
72090040 |
The property cannot be specified when converting a LUN into an NVMe namespace. The |
href |
string |
_links
source
The source NVMe namespace for a namespace clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same namespace.
Valid in POST to create a new NVMe namespace as a clone of the source.
Valid in PATCH to overwrite an existing NVMe namespace's data as a clone of another.
name |
string |
The name of the clone source NVMe namespace. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume. NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. Valid in POST and PATCH. |
uuid |
string |
The unique identifier of the clone source NVMe namespace. Valid in POST and PATCH. |
clone
When used in a PATCH, the patched NVMe namespace's data is over-written as a clone of the source and the following properties are preserved from the patched namespace unless otherwise specified as part of the PATCH: auto_delete (unless specified in the request), subsystem_map, status.state, and uuid.
source |
The source NVMe namespace for a namespace clone operation. This can be specified using property Valid in POST to create a new NVMe namespace as a clone of the source. Valid in PATCH to overwrite an existing NVMe namespace's data as a clone of another. |
consistency_group
name |
string |
The name of the consistency group. |
uuid |
string |
The unique identifier of the consistency group. |
lun
The source LUN for convert operation. This can be specified using property convert.lun.uuid or convert.lun.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST. A convert request from LUN to NVMe namespace cannot be combined with setting any other namespace properties. All other properties of the converted NVMe namespace come from the source LUN.
name |
string |
The name of the source LUN. Valid in POST. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume. LUN names are paths of the form "/vol/<volume>[/<qtree>]/<lun>" where the qtree name is optional. |
uuid |
string |
The unique identifier of the source LUN. Valid in POST. |
convert
lun |
The source LUN for convert operation. This can be specified using property Valid in POST. A convert request from LUN to NVMe namespace cannot be combined with setting any other namespace properties. All other properties of the converted NVMe namespace come from the source LUN. |
node
The cluster node that hosts the NVMe namespace.
name |
string |
uuid |
string |
qtree
The qtree in which the NVMe namespace is optionally located. Valid in POST.
If properties name and location.qtree.name and/or location.qtree.uuid are specified in the same request, they must refer to the same qtree.
NVMe namespaces do not support rename.
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. |
volume
The volume in which the NVMe namespace is located. Valid in POST.
If properties name and location.volume.name and/or location.volume.uuid are specified in the same request, they must refer to the same volume.
NVMe namespaces do not support movement between volumes.
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
location
namespace |
string |
The base name component of the NVMe namespace. Valid in POST. If properties NVMe namespaces do not support rename. |
node |
The cluster node that hosts the NVMe namespace. |
qtree |
The qtree in which the NVMe namespace is optionally located. Valid in POST. If properties NVMe namespaces do not support rename. |
volume |
The volume in which the NVMe namespace is located. Valid in POST. If properties NVMe namespaces do not support movement between volumes. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS latency and throughput
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
self_link
qos_policy
The QoS policy for the volume provisioned to host the namespace. This property is only supported when the request provisions a new volume. If no qos_policy is provided, a policy is be set based on the storage_service.name, which defaults to the most performant service available.
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
snapshot_policy_reference
This is a reference to the snapshot policy.
name |
string |
uuid |
string |
storage_service
Determines the placement of the namespace based on the value specified. Valid in POST.
name |
string |
Storage service name. If not specified, the default value is the most performant for the platform. |
object_stores
name |
string |
The name of the object store to use. Used for placement. |
tiering
The tiering placement and policy definitions for the volume provisioned to host the namespace. This property is only supported when the request provisions a new volume.
control |
string |
Storage tiering placement rules for the object. |
object_stores |
array[object_stores] |
Object stores to use. Used for placement. |
policy |
string |
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH. all ‐ Allows tiering of both snapshots and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks. auto ‐ Allows tiering of both snapshot and active file system user data to the cloud store none ‐ Volume blocks are not be tiered to the cloud store. snapshot_only ‐ Allows tiering of only the volume snapshots not associated with the active file system. The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy it is 31 days. |
auto |
boolean |
If the volume specified in the request does not exist, automatically provision one of appropriate size. If the volume does exist, resize it to accommodate the new namespace. This property is only supported on Unified ONTAP. The following behavior is different from a traditional POST request:
count |
integer |
The number of namespaces to provision with these properties. Only POST requests based on |
qos_policy |
The QoS policy for the volume provisioned to host the namespace. This property is only supported when the request provisions a new volume. If no |
snapshot_policy |
This is a reference to the snapshot policy. |
storage_service |
Determines the placement of the namespace based on the value specified. Valid in POST. |
tiering |
The tiering placement and policy definitions for the volume provisioned to host the namespace. This property is only supported when the request provisions a new volume. |
use_mirrored_aggregates |
boolean |
Specifies whether mirrored aggregates are selected when provisioning the volume to host the namespace. Only mirrored aggregates are used if this parameter is set to true and only unmirrored aggregates are used if this parameter is set to false. The default value is true for a MetroCluster configuration and is false for a non-MetroCluster configuration. |
guarantee
Properties that request and report the space guarantee for the NVMe namespace.
requested |
boolean |
The requested space reservation policy for the NVMe namespace. If true, a space reservation is requested for the namespace; if false, the namespace is thin provisioned. Guaranteeing a space reservation request for a namespace requires that the volume in which the namespace resides also be space reserved and that the fractional reserve for the volume be 100%. The space reservation policy for an NVMe namespace is determined by ONTAP.
reserved |
boolean |
Reports if the NVMe namespace is space guaranteed. This property is true if a space guarantee is requested and the containing volume and aggregate support the request. This property is false if a space guarantee is not requested or if a space guarantee is requested and either the containing volume and aggregate do not support the request. |
space
block_size |
integer |
The size of blocks in the namespace in bytes. The default for namespaces with an Valid in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone. Valid in POST. |
efficiency_ratio |
number |
The storage efficiency ratio of the namespace without snapshots. (Logical Used / Used) This property is not available on the namespace object in the REST API and is not reported for GET requests. See the containing volume object for this information. |
guarantee |
Properties that request and report the space guarantee for the NVMe namespace. |
physical_used |
integer |
The number of bytes consumed on the disk by the namespace, excluding snapshots. This property is not available on the namespace object in the REST API and is not reported for GET requests. See the containing volume object for this information. |
physical_used_by_snapshots |
integer |
The number of bytes consumed on the disk by the namespace's snapshots. This property is not available on the namespace object in the REST API and is not reported for GET requests. See the containing volume object for this information. |
size |
integer |
The total provisioned size of the NVMe namespace. Valid in POST and PATCH. The NVMe namespace size can be increased but not be made smaller using the REST interface. The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes in bytes. The maximum size is variable with respect to large NVMe namespace support in ONTAP. If large namespaces are supported, the maximum size is 128 TB (140737488355328 bytes) and if not supported, the maximum size is just under 16 TB (17557557870592 bytes). The minimum size supported is always 4096 bytes. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
used |
integer |
The amount of space consumed by the main data stream of the NVMe namespace. This value is the total space consumed in the volume by the NVMe namespace, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways NVMe filesystems and applications utilize blocks within a namespace, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the namespace blocks are utilized outside of ONTAP, this property should not be used and an indicator for an out-of-space condition. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
status
container_state |
string |
The state of the volume and aggregate that contain the NVMe namespace. Namespaces are only available when their containers are available. |
mapped |
boolean |
Reports if the NVMe namespace is mapped to an NVMe subsystem. There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the |
read_only |
boolean |
Reports if the NVMe namespace allows only read access. |
state |
string |
The state of the NVMe namespace. Normal states for a namespace are online and offline. Other states indicate errors. |
consistency_group_nvme_host_dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
controller_secret_key |
string |
The controller secret for NVMe in-band authentication. The value of this property is used by the NVMe host to authenticate the NVMe controller while establishing a connection. If unset, the controller is not authenticated. When supplied, the property This property is write-only. The |
group_size |
string |
The Diffie-Hellman group size for NVMe in-band authentication. When property |
hash_function |
string |
The hash function for NVMe in-band authentication. When property |
host_secret_key |
string |
The host secret for NVMe in-band authentication. The value of this property is used by the NVMe controller to authenticate the NVMe host while establishing a connection. If unset, no authentication is performed by the host or controller. This property must be supplied if any other NVMe in-band authentication properties are supplied. Optional in POST. This property is write-only. The |
mode |
string |
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
configured_psk |
string |
A user supplied pre-shared key (PSK) value in PSK Interchange Format. Optional in POST. The values for property This property is write-only. The |
key_type |
string |
The method by which the TLS pre-shared key (PSK) is configured for the host. Optional in POST. The values for property Possible values:
This property defaults to |
hosts
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
dh_hmac_chap |
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host. |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. |
priority |
string |
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies io_queue count and I/O queue depth are being used. |
tls |
A container for the configuration for NVMe/TCP-TLS transport session for the host. |
subsystem
The NVMe subsystem to which the NVMe namespace is mapped.
comment |
string |
A configurable comment for the NVMe subsystem. Optional in POST. |
hosts |
array[hosts] |
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST. |
name |
string |
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Optional in POST. |
os_type |
string |
The host operating system of the NVMe subsystem's hosts. Optional in POST. |
uuid |
string |
The unique identifier of the NVMe subsystem. |
subsystem_map
There is an added computational cost to retrieving property values for subsystem_map. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
These properties are supported only for GET.
anagrpid |
string |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
nsid |
string |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
subsystem |
The NVMe subsystem to which the NVMe namespace is mapped. |
svm
name |
string |
uuid |
string |
nvme_namespace
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the storage virtual machine using the NVMe over Fabrics protocol.
An NVMe namespace must be mapped to an NVMe subsystem to grant access to the subsystem's hosts. Hosts can then access the NVMe namespace and perform I/O using the NVMe over Fabrics protocol.
See the NVMe namespace object model to learn more about each of the properties supported by the NVMe namespace REST API. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
An NVMe namespace is created to a specified size using thin or thick provisioning as determined by the volume on which it is created. An NVMe namespace can then be resized or cloned. An NVMe namespace cannot be renamed, or moved to a different volume. NVMe namespaces do not support the assignment of a QoS policy for performance management, but a QoS policy can be assigned to the volume containing the namespace.
auto_delete |
boolean |
clone |
comment |
string |
consistency_group |
convert |
create_time |
string |
enabled |
boolean |
location |
name |
string |
os_type |
string |
space |
status |
subsystem_map |
svm |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
