Create a fingerprint computation session
POST /storage/snaplock/file-fingerprints
Introduced In: 9.7
Creates a fingerprint computation session on the file and returns a session-id. This session-id is a unique identifier that you can use to retrieve the progress of an ongoing fingerprint operation. When the operation is complete, you can use the session-id to retrieve the complete fingerprint output for the file .
Required properties
svm.uuidorsvm.name- Name or UUID of the SVM. -
volume.nameorvolume.uuid- Name or UUID of the volume. -
path- Path of the file.
Default property values
If not specified in POST, the follow default property values are assigned:
algorithm- sha256
Related ONTAP commands
volume file fingerprint start
Example
POST "/api/storage/snaplock/file-fingerprints" '{"svm":{"uuid":"23940494-3f3a-11e9-8675-0050568e8f89"},"volume": {"uuid":"26cdb58c-3f3a-11e9-8675-0050568e8f89"},"path":"/vol/a1.txt","algorithm":"md5"}'
Learn more
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
algorithm  |
string  |
The digest algorithm which is used for the fingerprint computation  |
data_fingerprint  |
string  |
The digest value of data of the file. The fingerprint is base64 encoded. This field is not included if the scope is metadata-only.  |
file_size  |
integer  |
The size of the file in bytes.  |
file_type  |
string  |
The type of the file.  |
id  |
integer  |
A unique identifier for the fingerprint operation  |
metadata_fingerprint  |
string  |
The digest value of metadata of the file. The metadata fingerprint is calculated for file size, file ctime, file mtime, file crtime, file retention time, file uid, file gid, and file type. The fingerprint is base64 encoded. This field is not included if the scope is data-only.  |
path  |
string  |
Specifies the path on which file fingerprint operation is running or has completed. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.  |
scope  |
string  |
The scope of the file which is used for the fingerprint computation  |
state  |
string  |
Specifies the status of fingerprint operation.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
volume  |
Example request
  "algorithm": "sha256",
  "data_fingerprint": "MOFJVevxNSJm3C/4Bn5oEEYH51CrudOzZYK4r5Cfy1g=",
  "file_size": 1048576,
  "file_type": "worm",
  "id": 17039367,
  "metadata_fingerprint": "8iMjqJXiNcqgXT5XuRhLiEwIrJEihDmwS0hrexnjgmc=",
  "path": "/homedir/dir1",
  "scope": "data_only",
  "state": "completed",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: 201, Created
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response codes
| Error code | Description |
2  |
An invalid value was entered for one of the fields  |
2621519  |
Invalid SVM name format  |
14090347  |
Invalid path format  |
14090443  |
Invalid volume name  |
14090444  |
Invalid Vserver name  |
14090447  |
Invalid volume UUID  |
14090448  |
Invalid key values. Provide valid Vserver name and volume name or Vserver UUID and volume UUID  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
volume
name  |
string  |
The name of the volume. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
snaplock_file_fingerprint
algorithm  |
string  |
data_fingerprint  |
string  |
file_size  |
integer  |
file_type  |
string  |
id  |
integer  |
string  |
path  |
string  |
scope  |
string  |
state  |
string  |
svm  |
volume  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
