Restore source directory
Restore a directory from a volume snapshot using this API without needing a data copy. The restored directory retains the original directory entries, with new inodes created in the Active File System that match the attributes in the source snapshot.
Overview
You can use this API to restore a directory from a volume snapshot without having to use data copy. The directory in the snapshot contains sub-directories and files.
When a directory from a volume snapshot is restored, all the directory entries (dentries) in the source should remain as they are (except for the junction path inodes). The dentries in the restored directory contain new inodes which are in the AFS (Active File System).
The newly created inodes in the AFS have the same attributes as those in the source snapshot.
Directory restore API
The following API is used to perform the following operations:
– POST /api/storage/directory-restore
