View and update Kerberos interfaces
Access and modify Kerberos interface configurations to manage authentication settings for your NFS protocols. Use these endpoints to retrieve current configurations or update interface settings as needed.
Retrieving the Kerberos interface configuration details
# The API: GET /api/protocols/nfs/kerberos/interfaces # The call: curl -X GET "https://<mgmt-ip>/api/protocols/nfs/kerberos/interfaces"
Updating the Kerberos interface configuration
# The API:
PATCH /api/protocols/nfs/kerberos/interfaces/{interface.uuid}
# The call:
curl -d "@test_patch_kerb_interface.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/kerberos/interfaces/e62936de-7342-11e8-9eb4-0050568be2b7"
test_patch_kerb_interface.txt(body):
"enabled" : "true",
"spn": "nfs/datalif1-vsim3-d1.sim.netapp.com@NFS-NSR-W01.RTP.NETAPP.COM",
"user" :"administrator",
"password" :"Hello123!"
