REST API reference
Delete the local user configuration for an SVM
Deletes the local user configuration for a specified SVM, removing the user from the system.
HTTP method and endpoint
DELETE /protocols/cifs/local-users/{svm.uuid}/{sid}
Introduced in
ONTAP 9.10
  • vserver cifs users-and-groups local-user delete
sid
string
path
True
Local user SID
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655735
The local Administrator account cannot be deleted.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
