REST API reference
Delete the SAML default metadata configuration
Deletes the SAML default metadata configuration when you need to remove an existing configuration setup.
HTTP method and endpoint
DELETE /security/authentication/cluster/saml-sp/default-metadata
Introduced in
ONTAP 9.17
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
12320817
Internal Error. The SAML service provider metadata configuration is being created, but is taking longer than expected to complete.
12320826
SAML configuration already exists. Cannot delete the metadata when SAML configuration is already present.
12320832
Internal Error. Failed to execute the command, web server setup is in progress. Retry after some time.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
