REST API reference
Delete an AWS KMS configuration
Removes an AWS KMS configuration to manage encryption settings and security options for your data.
HTTP method and endpoint
DELETE /security/aws-kms/{uuid}
Introduced in
ONTAP 9.12
Usage notes
Deletes an AWS KMS configuration.
  • security key-manager external aws disable
uuid
string
path
True
AWS KMS UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65536817
Internal error. Failed to determine if it is safe to disable key manager.
65536827
Internal error. Failed to determine if the given SVM has any encrypted volumes.
65536834
Internal error. Failed to get existing key-server details for the given SVM.
65536883
Internal error. Volume encryption key is missing for a volume.
65536884
Internal error. Volume encryption key is invalid for a volume.
65537106
Volume encryption keys (VEK) for one or more encrypted volumes are stored on the key manager configured for the given SVM.
65537926
Amazon Web Service Key Management Service is not configured for SVM.
196608080
One or more nodes in the cluster have the root volume encrypted using NVE (NetApp Volume Encryption).
196608301
Internal error. Failed to get encryption type.
196608332
NAE aggregates found in the cluster.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
