REST API reference
Delete a group entry
DELETE /security/groups/{owner.uuid}/{name}/{type}
Introduced In: 9.16
Deletes a group entry.
  • security login group delete
owner.uuid
string
path
True
name
string
path
True
type
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5636244
The group is part of the role mapping configuration. Delete the mapping first and then delete the group.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
