REST API reference
Retrieve host cache settings
Retrieves host cache settings to view the current configuration for caching host entries.
HTTP method and endpoint
GET /name-services/cache/host/settings
Introduced in
ONTAP 9.11
  • vserver services name-service cache hosts settings show
enabled
boolean
query
False
Filter by enabled
dns_ttl_enabled
boolean
query
False
Filter by dns_ttl_enabled
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
negative_cache_enabled
boolean
query
False
Filter by negative_cache_enabled
ttl
string
query
False
Filter by ttl
uuid
string
query
False
Filter by uuid
  • Introduced in: 9.14
negative_ttl
string
query
False
Filter by negative_ttl
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[hosts_settings]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "dns_ttl_enabled": 1,
      "negative_ttl": "PT5M",
      "svm": {
        "name": "svm1",
      "ttl": "PT24H",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
hosts_settings
Hosts cache setting.
_links
_links
dns_ttl_enabled
boolean
Specifies whether TTL is based on the DNS or host settings. If enabled, TTL from DNS is used.
enabled
boolean
Indicates whether or not the cache is enabled.
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl
string
Specifies negative Time to Live, in ISO 8601 format.
svm
svm
ttl
string
Specifies Time to Live (TTL), in ISO 8601 format.
uuid
string
UUID for the host record.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
