Retrieve FC fabric switches
GET /network/fc/fabrics/{fabric.name}/switches
Introduced In: 9.11
Retrieves the Fibre Channel switches of a Fibre Channel fabric.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
ports
Related ONTAP commands
network fcp topology show
Learn more
fabric.name |
string |
path |
True |
The WWN of the primary switch of the Fibre Channel fabric. |
ports.wwpn |
string |
query |
False |
Filter by ports.wwpn |
ports.slot |
string |
query |
False |
Filter by ports.slot |
ports.type |
string |
query |
False |
Filter by ports.type |
ports.attached_device.wwpn |
string |
query |
False |
Filter by ports.attached_device.wwpn |
ports.attached_device.port_id |
string |
query |
False |
Filter by ports.attached_device.port_id |
ports.state |
string |
query |
False |
Filter by ports.state |
domain_id |
integer |
query |
False |
Filter by domain_id
wwn |
string |
query |
False |
Filter by wwn |
cache.age |
string |
query |
False |
Filter by cache.age |
cache.is_current |
boolean |
query |
False |
Filter by cache.is_current |
cache.update_time |
string |
query |
False |
Filter by cache.update_time |
release |
string |
query |
False |
Filter by release |
vendor |
string |
query |
False |
Filter by vendor |
name |
string |
query |
False |
Filter by name |
cache.maximum_age |
string |
query |
False |
The maximum age of data in the Fibre Channel fabric cache before it should be refreshed from the fabric. The default is 15 minutes.
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[fc_switch] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"cache": {
"age": "PT3M30S",
"update_time": "string"
"domain_id": 1,
"fabric": {
"name": "10:00:d1:d2:d3:d4:d5:d6"
"name": "switch1",
"ports": [
"attached_device": {
"port_id": 70400,
"wwpn": "50:0a:21:22:23:24:25:26"
"slot": 1,
"state": "online",
"type": "string",
"wwpn": "50:0a:31:32:33:34:35:36"
"release": "1.0.",
"vendor": "vendor1",
"wwn": "10:00:e1:e2:e3:e4:e5:e6"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5373982 |
An invalid WWN was specified. The length is incorrect. |
5373983 |
An invalid WWN was specified. The format is incorrect. |
5375053 |
The Fibre Channel fabric specified by name in the request URI was not found in the FC fabric cache. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
cache
Properties of Fibre Chanel fabric cache.
age |
string |
The age of the Fibre Channel fabric data cache retrieved. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved. The value is in ISO 8601 duration format. |
is_current |
boolean |
A boolean that indicates if the retrieved data is current relative to the |
update_time |
string |
The date and time at which the Fibre Channel fabric data cache retrieved was last updated. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved. |
fabric
A reference to a Fibre Channel fabric.
_links |
name |
string |
The world wide name (WWN) of the primary switch of the Fibre Channel (FC) fabric. This is used as a unique identifier for the FC fabric. |
attached_device
The Fibre Channel (FC) device attached to the FC switch port.
port_id |
string |
The Fibre Channel port identifier of the attach device. |
wwpn |
string |
The world-wide port name (WWPN) of the attached device. |
ports
A Fibre Channel switch port.
attached_device |
The Fibre Channel (FC) device attached to the FC switch port. |
slot |
string |
The slot of the Fibre Channel switch port. |
state |
string |
The state of the Fibre Channel switch port. |
type |
string |
The type of the Fibre Channel switch port. |
wwpn |
string |
The world wide port name (WWPN) of the Fibre Channel switch port. |
fc_switch
A Fibre Channel switch.
_links |
cache |
Properties of Fibre Chanel fabric cache. |
domain_id |
integer |
The domain identifier (ID) of the Fibre Channel (FC) switch. The domain ID is a unique identifier for the FC switch in the FC fabric. |
fabric |
A reference to a Fibre Channel fabric. |
name |
string |
The logical name of the Fibre Channel switch. |
ports |
array[ports] |
An array of the Fibre Channel (FC) switch's ports and their attached FC devices. |
release |
string |
The firmware release of the Fibre Channel switch. |
vendor |
string |
The vendor of the Fibre Channel switch. |
wwn |
string |
The world-wide name (WWN) for the Fibre Channel switch. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
