REST API reference
Retrieve details for an IP route
Retrieves detailed information about a specific IP route, helping you understand its configuration and properties for effective network management.
HTTP method and endpoint
GET /network/ip/routes/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the details of a specific IP route.
  • network route show
  • network route show-lifs
uuid
string
path
True
Route UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
destination
ip_info
IP information
gateway
string
The IP address of the gateway router leading to the destination.
interfaces
array[interfaces]
IP interfaces on the same subnet as the gateway.
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
metric
integer
Indicates a preference order between several routes to the same destination. With typical usage, the default metrics provided are adequate, there is no need to specify a metric in the route creation.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
svm
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied.
uuid
string
The UUID that uniquely identifies the route.
      "href": "/api/resourcelink"
  "destination": {
    "address": "10.10.10.7",
    "family": "string",
    "netmask": "24"
  "gateway": "10.1.1.1",
  "interfaces": [
      "ip": {
      "name": "lif1",
  "ipspace": {
    "name": "Default",
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ip_info
IP information
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
ip
IP information
address
string
interfaces
A network interface. Either UUID or name may be supplied on input.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
