REST API reference
Retrieve the S3 server configuration for an SVM
Accesses the S3 server configuration for a specific SVM, which is essential for managing S3 storage capabilities within your environment.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 Server configuration of an SVM. Note that in order to retrieve S3 bucket policy conditions, the 'fields' option should be set to '**'.
  • vserver object-store-server show
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
buckets
array[s3_bucket]
This field cannot be specified in a PATCH method.
certificate
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
comment
string
Can contain any additional information about the server being created or modified.
default_unix_user
string
Specifies the default UNIX user for NAS Access.
default_win_user
string
Specifies the default Windows user for NAS Access.
enabled
boolean
Specifies whether the S3 server being created or modified should be up or down.
is_http_enabled
boolean
Specifies whether HTTP is enabled on the S3 server being created or modified. By default, HTTP is disabled on the S3 server.
is_https_enabled
boolean
Specifies whether HTTPS is enabled on the S3 server being created or modified. By default, HTTPS is enabled on the S3 server.
max_key_time_to_live
string
Indicates the maximum time period that an S3 user can specify for the 'key_time_to_live' property.
  • Valid format is: 'PnDTnHnMnS|PnW'. For example, P2DT6H3M10S specifies a time period of 2 days, 6 hours, 3 minutes, and 10 seconds.
  • If no value is specified for this property or the value specified is '0' seconds, then a user can specify any valid value.
max_lock_retention_period
string
Specifies the maximum value that can be set as the retention period for an object in a bucket with locking enabled. The value for this property can be in years or days, not both. The value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years.
metric
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
min_lock_retention_period
string
Specifies the minimum value that can be set as the retention period for an object in a bucket with locking enabled. The value for this property can be in years or days, not both. The value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years.
name
string
Specifies the name of the S3 server. A server name can contain 3 to 253 characters using only the following combination of characters':' 0-9, A-Z, a-z, ".", and "-".
port
integer
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80. Valid values range from 1 to 65535.
secure_port
integer
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443. Valid values range from 1 to 65535.
statistics
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
svm
svm
users
array[s3_user]
      "href": "/api/resourcelink"
  "buckets": [
      "audit_event_selector": {
        "access": "string",
        "permission": "string"
      "comment": "S3 bucket.",
      "cors": {
        "rules": [
            "allowed_headers": [
              "x-amz-request-id"
            "allowed_methods": [
              "PUT",
              "DELETE"
            "allowed_origins": [
              "http://www.example.com"
            "expose_headers": [
              "x-amz-date"
            "id": "string",
            "max_age_seconds": 1024
      "lifecycle_management": {
        "rules": [
            "abort_incomplete_multipart_upload": {
            "bucket_name": "bucket1",
            "expiration": {
              "object_age_days": 100,
              "object_expiry_date": "2039-09-22 20:00:00 -0400"
            "name": "string",
            "non_current_version_expiration": {
            "object_filter": {
              "prefix": "/logs",
              "size_greater_than": 10240,
              "size_less_than": 10485760,
              "tags": [
                "project1=projA",
                "project2=projB"
            "svm": {
              "name": "svm1",
            "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
      "logical_used_size": 0,
      "name": "bucket1",
      "nas_path": "/",
      "policy": {
        "statements": [
            "actions": [
              "GetObject",
              "PutObject",
              "DeleteObject",
              "ListBucket"
            "conditions": [
                "delimiters": [
                "max_keys": [
                  1000
                "operator": "ip_address",
                "prefixes": [
                  "pref"
                "source_ips": [
                  "1.1.1.1",
                  "1.2.2.0/24"
                "usernames": [
                  "user1"
            "effect": "allow",
            "principals": [
              "user1",
              "group/grp1",
              "nasgroup/group1"
            "resources": [
              "bucket1",
              "bucket1/*"
            "sid": "FullAccessToUser1"
      "qos_policy": {
        "max_throughput": [
          "900KB/s",
          "500MB/s",
          "120GB/s",
          "5000IOPS",
          "5000IOPS,500KB/s",
          "2500IOPS,100MB/s",
          "1000IOPS,25MB/s"
        "max_throughput_iops": 10000,
        "max_throughput_mbps": 500,
        "min_throughput": [
          "900KB/s",
          "500MB/s",
          "120GB/s",
          "5000IOPS",
          "5000IOPS,500KB/s",
          "2500IOPS,100MB/s",
          "1000IOPS,25MB/s"
        "min_throughput_iops": 2000,
        "min_throughput_mbps": 500,
        "name": "performance",
      "retention": {
        "default_period": "P10Y",
        "mode": "governance"
      "role": "string",
      "size": 1677721600,
      "snapshot_policy": {
        "name": "default-1weekly",
        "uuid": "3675af31-431c-12fa-114a-20675afebc12"
      "svm": {
        "name": "svm1",
      "type": "s3",
      "use_mirrored_aggregates": true,
      "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
      "versioning_state": "enabled",
      "volume": {
        "name": "volume1",
  "certificate": {
    "name": "string",
  "comment": "S3 server",
  "default_unix_user": "string",
  "default_win_user": "string",
  "max_key_time_to_live": "PT6H3M",
  "max_lock_retention_period": "P10Y",
  "metric": {
    "duration": "PT15S",
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
    "timestamp": "2017-01-25 06:20:13 -0500"
  "min_lock_retention_period": "P10Y",
  "name": "Server-1",
  "port": 80,
  "secure_port": 443,
  "statistics": {
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
  "svm": {
    "name": "svm1",
  "users": [
      "access_key": "<AWS-ACCESS-KEY-ID>",
      "comment": "S3 user",
      "key_expiry_time": "2023-12-31 19:00:00 -0500",
      "key_time_to_live": "PT6H3M",
      "name": "user-1",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
aggregates
Aggregate
_links
_links
name
string
uuid
string
Audit event selector allows you to specify access and permission types to audit.
access
string
Specifies read and write access types.
permission
string
Specifies allow and deny permission types.
rules
Information about the CORS rule of an S3 bucket.
_links
_links
allowed_headers
array[string]
An array of HTTP headers allowed in the cross-origin requests.
allowed_methods
array[string]
An array of HTTP methods allowed in the cross-origin requests.
allowed_origins
array[string]
List of origins from where a cross-origin request is allowed to originate from for the S3 bucket.
expose_headers
array[string]
List of extra headers sent in the response that customers can access from their applications.
id
string
Bucket CORS rule identifier. The length of the name can range from 0 to 256 characters.
max_age_seconds
integer
The time in seconds for your browser to cache the preflight response for the specified resource.
cors
Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully.
rules
array[rules]
Specifies an object store bucket CORS rule.
encryption
enabled
boolean
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. This field cannot be specified in a POST method.
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
_links
_links
after_initiation_days
integer
Number of days of initiation after which uploads can be aborted.
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
_links
_links
expired_object_delete_marker
boolean
Cleanup object delete markers.
object_age_days
integer
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date.
object_expiry_date
string
Specific date from when objects can expire. This cannot be used with object_age_days.
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
_links
_links
new_non_current_versions
integer
Number of latest non-current versions to be retained.
non_current_days
integer
Number of days after which non-current versions can be deleted.
object_filter
Specifies a way to filter objects within a bucket.
_links
_links
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form or <tag=value>.
svm
Specifies the name of the SVM where this bucket exists.
_links
_links
name
string
uuid
string
rules
Information about the lifecycle management rule of a bucket.
_links
_links
bucket_name
string
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
name
string
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters.
object_filter
object_filter
svm
svm
uuid
string
Specifies the unique identifier of the bucket.
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
rules
array[rules]
Specifies an object store lifecycle management policy.
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters
array[string]
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
max_keys
array[integer]
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
operator
string
Condition operator that is applied to the specified condition key.
prefixes
array[string]
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
source_ips
array[string]
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
usernames
array[string]
An array of usernames that a current user in the context is evaluated against using the condition operators.
s3_bucket_policy_statement
Specifies information about a single access permission.
actions
array[string]
conditions
array[s3_bucket_policy_condition]
Specifies bucket policy conditions.
effect
string
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
principals
array[string]
resources
array[string]
sid
string
Specifies the statement identifier used to differentiate between statements. The sid length can range from 1 to 256 characters and can only contain the following combination of characters 0-9, A-Z, and a-z. Special characters are not valid.
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
statements
array[s3_bucket_policy_statement]
Specifies bucket access policy statement.
destination
is_cloud
boolean
Specifies whether a bucket is protected within the Cloud. This field cannot be specified using a POST method.
is_external_cloud
boolean
Specifies whether a bucket is protected on external Cloud providers. This field cannot be specified using a POST method.
is_ontap
boolean
Specifies whether a bucket is protected within ONTAP. This field cannot be specified using a POST method.
  • Default value: 1
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
protection_status
Specifies attributes of bucket protection.
destination
destination
is_protected
boolean
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud. This field cannot be specified using a POST method.
  • Default value: 1
  • readOnly: 1
  • x-nullable: true
qos_policy
Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
_links
_links
max_throughput
string
Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
min_throughput
string
Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
retention
Specifies the retention mode and default retention period configured on the bucket.
default_period
string
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported.
mode
string
The lock mode of the bucket. compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. governance ‐ An administrator can delete a Governance bucket. no_lock ‐ Indicates the bucket does not support object locking.
snapshot_policy
Specifies the bucket snapshot policy.
name
string
Specifies the name of the snapshot policy.
uuid
string
Specifies the unique identifier of the snapshot policy.
svm
_links
_links
name
string
uuid
string
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
allowed
boolean
If this is set to true, an SVM administrator can manage the S3 service. If it is false, only the cluster administrator can manage the service. This field cannot be specified in a POST method.
comment
string
Can contain any additional information about the bucket being created or modified.
cors
cors
encryption
encryption
is_consistent_etag
boolean
Specifies whether the NAS bucket returns a consistent ETag across different S3 requests.
is_nas_path_mutable
boolean
Specifies whether the NAS bucket mapping or association with a NAS volume can change according to the changes in the NAS volume junction-path due to volume operations like mount and unmount and therefore the NAS bucket will have access to any path in a NAS volume that matches the specified nas-path. Or is immutable and therefore the NAS bucket will always have access to the same nas-path that was specified during bucket creation even if the volume junction-path has undergone changes after the bucket creation.
logical_used_size
integer
Specifies the bucket logical used size up to this point. This field cannot be specified using a POST or PATCH method.
name
string
nas_path
string
Specifies the NAS path to which the nas bucket corresponds to.
policy
policy
protection_status
protection_status
qos_policy
qos_policy
retention
retention
role
string
Specifies the role of the bucket. This field cannot be specified using a POST method.
size
integer
Specifies the bucket size in bytes; ranges from 190MB to 62PB.
snapshot_policy
snapshot_policy
svm
svm
type
string
Specifies the bucket type. Valid values are "s3"and "nas".
uuid
string
versioning_state
string
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state.
volume
volume
certificate
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
s3_user
This is a container of S3 users.
access_key
string
Specifies the access key for the user.
comment
string
Can contain any additional information about the user being created or modified.
key_expiry_time
string
Specifies the date and time after which keys expire and are no longer valid.
key_time_to_live
string
Indicates the time period from when this parameter is specified:
  • when creating or modifying a user or
  • when the user keys were last regenerated, after which the user keys expire and are no longer valid.
  • If the value specified is '0' seconds, then the keys won't expire.
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
