REST API reference
Retrieve a data-entropy statistic for a volume
GET /security/anti-ransomware/volume/entropy-stats/{volume.uuid}/{entropy_stats_type}/{timestamp}
Introduced In: 9.17
Retrieves a data-entropy statistic for the volumes.
volume.uuid
string
path
True
The UUID of the volume.
entropy_stats_type
string
path
True
The type of entropy statistics.
  • enum: ["sub_hourly", "hourly", "daily", "high_enc_pct"]
timestamp
string
path
True
The timestamp of the statistics.
  • format: date-time
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
data_written_in_bytes
integer
The amount of data written.
duration
string
The duration of the interval associated with this statistic. The duration is represented in ISO-8601 standard format.
encryption_percentage
integer
The percentage of data that is encrypted.
entropy_stats_type
string
Volume metrics are retrieved based on this statistic type.
timestamp
string
Start time in date-time format.
volume
volume
      "href": "/api/resourcelink"
  "data_written_in_bytes": 0,
  "duration": "PT15M",
  "encryption_percentage": 0,
  "entropy_stats_type": "string",
  "timestamp": "string",
  "volume": {
    "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
