REST API reference
Retrieve the Google Cloud KMS configuration
GET /security/gcp-kms/{uuid}
Introduced In: 9.9
Retrieves the Google Cloud KMS configuration for the SVM specified by the UUID.
  • security key-manager external gcp show
  • security key-manager external gcp check
uuid
string
path
True
Google Cloud KMS UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication_method
string
Google Cloud KMS authentication method.
caller_account
string
Google Cloud KMS caller account email
cloudkms_host
string
Google Cloud KMS host subdomain.
ekmip_reachability
array[ekmip_reachability]
gce_metadata_server
string
A custom metadata server URL used for retrieving short lived authentication tokens if the default service account is not used. This is only applicable when the authentication_method is set to sa_credentials_attachment.
google_reachability
google_reachability
Indicates whether or not the Google Cloud KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
key_name
string
Key Identifier of Google Cloud KMS key encryption key.
key_ring_location
string
Google Cloud KMS key ring location.
key_ring_name
string
Google Cloud KMS key ring name of the deployed Google Cloud application.
oauth_host
string
Open authorization server host name.
oauth_url
string
Open authorization URL for the access token.
port
integer
Authorization server and Google Cloud KMS port number.
privileged_account
string
Google Cloud KMS account to impersonate.
project_id
string
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS.
proxy_host
string
Proxy host name.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
svm
uuid
string
A unique identifier for the Google Cloud KMS.
verify_host
boolean
Verify the identity of the Google Cloud KMS host name.
verify_ip
boolean
Verify the identity of the Google Cloud KMS IP address.
      "href": "/api/resourcelink"
  "authentication_method": "application_credentials_key",
  "caller_account": "myaccount@myproject.com",
  "cloudkms_host": "cloudkms.googleapis.com",
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "gce_metadata_server": "http://169.254.169.254/computeMetadata/v1/instance/service-accounts/default/token",
  "google_reachability": {
    "code": "346758",
    "message": "Google Cloud KMS is not reachable from all nodes - <reason>."
  "key_name": "cryptokey1",
  "key_ring_location": "global",
  "key_ring_name": "gcpapp1-keyring",
  "oauth_host": "oauth2.googleapis.com",
  "oauth_url": "https://oauth2.googleapis.com/token",
  "port": 443,
  "privileged_account": "myserviceaccount@myproject.iam.gserviceaccount.com",
  "project_id": "gcpapp1",
  "proxy_host": "proxy.eng.com",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "scope": "string",
  "state": {
    "code": "346758",
    "message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
65537551
Top-level internal key protection key (KEK) unavailable on one or more nodes.
65537552
Embedded KMIP server status not available.
65537730
The Google Cloud Key Management Service is unreachable from one or more nodes.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
_links
_links
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
google_reachability
code
string
Code corresponding to the error message. Returns a 0 if Google Cloud KMS is reachable from all nodes in the cluster.
message
string
Set to the error message when 'reachable' is false.
reachable
boolean
Set to true if the Google Cloud KMS is reachable from all nodes of the cluster.
state
cluster_state
boolean
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster.
code
string
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
