REST API reference
Retrieve ongoing operations for a litigation ID
Retrieves the list of ongoing operations associated with a specific litigation ID. This is useful for monitoring and managing legal hold processes in your storage environment.
HTTP method and endpoint
GET /storage/snaplock/litigations/{id}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the list of ongoing operations for the specified litigation ID.
  • snaplock legal-hold show
id
string
path
True
Litigation ID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
id
string
Specifies the litigation ID.
name
string
Specifies the legal-hold litigation name.
operations
array[snaplock_legal_hold_operation]
svm
svm
volume
volume
      "href": "/api/resourcelink"
  "id": "string",
  "name": "lit1",
  "operations": [
      "id": 16842759,
      "num_files_failed": 0,
      "num_files_processed": 30,
      "num_files_skipped": 10,
      "num_inodes_ignored": 10,
      "path": "/dir1",
      "state": "completed",
      "type": "begin"
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
13763280
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.
14090346
Internal Error. Wait a few minutes, then try the command again
14090343
Invalid Field
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
id
integer
Operation ID.
num_files_failed
string
Specifies the number of files on which legal-hold operation failed.
num_files_processed
string
Specifies the number of files on which legal-hold operation was successful.
num_files_skipped
string
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.
num_inodes_ignored
string
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
path
string
Specifies the path on which legal-hold operation is applied.
state
string
Specifies the status of legal-hold operation.
type
string
Specifies the type of legal-hold operation.
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
