REST API reference
Retrieve the AutoSupport configuration
Accesses the AutoSupport configuration of the cluster, with the option to check for any connectivity issues related to the configuration. This is useful for diagnosing and resolving potential communication problems with AutoSupport servers.
HTTP method and endpoint
GET /support/autosupport
Introduced in
ONTAP 9.6
Usage notes
Retrieves the AutoSupport configuration of the cluster and if requested, returns connectivity issues with the AutoSupport configuration.
Important note:
  • The issues field consists of a list of objects containing details of the node that has a connectivity issue, the issue description, and corrective action you can take to address the issue. When not empty, this indicates a connection issue to the HTTPS, SMTP, or AutoSupport On Demand server.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • issues
  • system node autosupport show -instance
  • system node autosupport check show-details
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
contact_support
boolean
Specifies whether to send the AutoSupport messages to vendor support.
enabled
boolean
Specifies whether the AutoSupport daemon is enabled. When this setting is disabled, delivery of all AutoSupport messages is turned off.
from
string
The e-mail address from which the AutoSupport messages are sent. To generate node-specific 'from' addresses, enable '-node-specific-from' parameter via ONTAP CLI.
is_minimal
boolean
Specifies whether the system information is collected in compliant form, to remove private data or in complete form, to enhance diagnostics.
issues
array[autosupport_issues]
A list of connectivity issues to the HTTPS/SMTP/AOD AutoSupport destinations on the nodes in the cluster along with the corrective actions.
mail_hosts
array[string]
The names of the mail servers used to deliver AutoSupport messages via SMTP.
ondemand_enabled
boolean
Specifies whether the AutoSupport OnDemand feature is enabled. When AutoSupport OnDemand is enabled, support personnel can remotely trigger new AutoSupport messages, resend existing AutoSupport messages, and decline the delivery of unwanted AutoSupport messages. When this option is disabled, the cluster does not respond to any AutoSupport OnDemand requests from support personnel.
partner_addresses
array[string]
The list of partner addresses.
proxy_url
string
Proxy server for AutoSupport message delivery via HTTPS. Optionally specify a username/password for authentication with the proxy server.
smtp_encryption
string
The encryption protocol used to deliver AutoSupport messages via SMTP to the configured mail_hosts.
to
array[string]
The e-mail addresses to which the AutoSupport messages are sent.
transport
string
The name of the transport protocol used to deliver AutoSupport messages.
Note 'http' transport is no longer supported by AutoSupport servers.
  "contact_support": 1,
  "enabled": 1,
  "from": "postmaster@example.com",
  "is_minimal": 1,
  "issues": [
      "component": "mail_server",
      "corrective_action": {
        "code": "53149746",
        "message": "Check the hostname of the SMTP server"
      "destination": "mailhost1.example.com",
      "issue": {
        "code": "53149746",
        "message": "SMTP connectivity check failed for destination: mailhost. Error: Could not resolve host - 'mailhost'"
      "node": {
            "href": "/api/resourcelink"
        "name": "node1",
  "mail_hosts": [
    "mailhost2.example.com"
  "ondemand_enabled": 1,
  "partner_addresses": [
    "user1@partner.com",
    "user2@partner.com"
  "proxy_url": "proxy.company.com",
  "smtp_encryption": "none",
  "to": [
    "user1@example.com",
    "user2@example.com"
  "transport": "smtp"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
autosupport_connectivity_corrective_action
code
string
Corrective action code
message
string
Corrective action message. The corrective action might contain commands which needs to be executed on the ONTAP CLI.
  • example: Check the hostname of the SMTP server
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
autosupport_connectivity_issue
code
string
Error code
message
string
Error message
string
self
node
_links
_links
name
string
uuid
string
autosupport_issues
component
string
The name of the component where the issue occurred.
corrective_action
destination
string
The HTTPS/SMTP/AOD AutoSupport Destination.
issue
node
node
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
