REST API reference
Retrieve event filter rules
Retrieves event filter rules to understand which events are being filtered based on specific criteria in your ONTAP environment.
HTTP method and endpoint
GET /support/ems/filters/{name}/rules
Introduced in
ONTAP 9.6
  • event filter show
name
string
path
True
Filter Name
message_criteria.severities
string
query
False
Filter by message_criteria.severities
message_criteria.snmp_trap_types
string
query
False
Filter by message_criteria.snmp_trap_types
message_criteria.name_pattern
string
query
False
Filter by message_criteria.name_pattern
index
integer
query
False
Filter by index
type
string
query
False
Filter by type
parameter_criteria.value_pattern
string
query
False
Filter by parameter_criteria.value_pattern
  • Introduced in: 9.13
parameter_criteria.name_pattern
string
query
False
Filter by parameter_criteria.name_pattern
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "index": 1,
      "message_criteria": {
          "related": {
        "name_pattern": "wafl.*",
        "severities": "emergency,alert,error",
        "snmp_trap_types": "standard,built_in"
      "parameter_criteria": [
          "name_pattern": "vol",
          "value_pattern": "cloud*"
      "type": "include"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
related
message_criteria
Matching message definitions for the filter. A property must be specified.
_links
_links
name_pattern
string
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.
severities
string
A comma-separated list of severities or a wildcard.
snmp_trap_types
string
A comma separated list of snmp_trap_types or a wildcard.
parameter_criteria
Criterion used for parameter based filtering
name_pattern
string
Parameter name pattern. Wildcard character '*' is supported.
value_pattern
string
Parameter value pattern. Wildcard character '*' is supported.
records
Rule for an event filter
_links
_links
index
integer
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.
message_criteria
message_criteria
parameter_criteria
array[parameter_criteria]
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters.
type
string
Rule type
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
