REST API reference
Retrieve the volume transfer status for a volume
Retrieves the transfer status of a specific volume, which helps you monitor the progress and details of ongoing volume transfers.
HTTP method and endpoint
GET /svm/migrations/{svm_migration.uuid}/volumes/{volume.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the volume transfer status of the specified volume.uuid.
  • vserver migrate show-volume
svm_migration.uuid
string
path
True
Migration UUID
volume.uuid
string
path
True
Volume UUID
transfer_state
string
query
False
Filter by transfer_state
volume.name
string
query
False
Filter by volume.name
errors.code
string
query
False
Filter by errors.code
errors.message
string
query
False
Filter by errors.message
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
healthy
boolean
query
False
Filter by healthy
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
self_link
errors
array[errors]
List of transfer errors
healthy
boolean
Indicates whether the volume transfer relationship is healthy.
node
node
Node in the destination cluster where the volume is hosted
svm
svm
SVM information
transfer_state
string
Status of the transfer.
volume
volume
Volume information in the destination cluster
      "href": "/api/resourcelink"
  "errors": [
      "code": "string",
      "message": "string"
  "node": {
    "name": "node1",
  "svm": {
    "name": "svm1",
  "transfer_state": "string",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
13172783
Migrate RDB lookup failed
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
errors
code
string
Argument code
message
string
Message argument
self
node
_links
_links
name
string
uuid
string
svm
SVM information
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
