REST API reference
Manage a multi-admin-verify approval request
These APIs provide the necessary tools to manage multi-admin verification requests, ensuring commands protected by multi-admin rules are executed securely. You can retrieve and update requests to facilitate the approval process as dictated by the associated command rules.
Overview
These APIs provide information about a specific multi-admin verification request. If you need to execute a command that is protected by a multi-admin rule, you must first submit a request to be allowed to execute the command. The request must then be approved by the designated approvers according to the rule associated with the command.
Retrieving a multi-admin-verify request
Retrieves information about a specific multi-admin verification request.
# The API:
/api/security/multi-admin-verify/requests/{index}
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/requests/1"
# The response:
"index": 1,
"operation": "security multi-admin-verify modify",
"query": "",
"state": "expired",
"required_approvers": 1,
"pending_approvers": 1,
"execute_on_approval": false,
"permitted_users": [
  "example_user"
"user_requested": "admin",
"owner": {
  "uuid": "c1483186-6e73-11ec-bc92-005056a7ad04",
  "name": "cluster1",
      "href": "/api/svm/svms/c1483186-6e73-11ec-bc92-005056a7ad04"
"create_time": "2022-01-05T20:07:09-05:00",
"approve_expiry_time": "2022-01-05T21:07:09-05:00",
    "href": "/api/security/multi-admin-verify/requests/1"
Updating a multi-admin-verify request
Updates a specific multi-admin-verify request
# The API:
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/multi-admin-verify/requests/1" -d '{"state": "approved", "execute_on_approval": false}'
