REST API reference
Manage a multi-admin-verify rule
Use these endpoints to access and manage multi-admin verification rules in your ONTAP environment. These rules specify which operations require multi-admin approval, ensuring that sensitive commands are executed securely.
Overview
These APIs provide information about a specific multi-admin verification rule. Rules define the ONTAP commands (operations) that should be protected by multi-admin approval. While the feature is turned on, any ONTAP operation that is defined with a rule will be enforced with multi-admin approval to execute the command (operation).
Retrieving a multi-admin-verify rule
Displays information about a specific multi admin verification rule.
# The API:
/api/security/multi-admin-verify/rules/{owner.uuid}/{operation}
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume+delete"
# The response:
"owner": {
  "uuid": "52b75787-7011-11ec-a23d-005056a78fd5",
  "name": "cluster1",
      "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5"
"operation": "volume delete",
"auto_request_create": true,
"query": "-vserver vs0",
"required_approvers": 1,
"create_time": "2022-01-07T22:14:03-05:00",
"system_defined": false,
    "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume+delete"
Updating a multi-admin-verify rule
Modifies the attributes of the rule.
# The API:
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume+delete" -d '{"required_approvers": 1}'
Deleting a multi-admin-verify rule
Deletes the specified approval group.
# The API:
# The call:
curl -X DELETE "https://<cluster-ip>/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume+delete"
