REST API reference
Manage group membership cache settings
Utilize group-membership cache settings endpoints to efficiently retrieve and manage caching configurations within your ONTAP environment. Access these endpoints to optimize cache behavior for specific storage virtual machines (SVMs).
Overview
This API is used to retrieve and manage group-membership cache settings.
Retrieving group-membership cache settings
The following example shows how to use the cache group-membership settings GET endpoint to retrieve group-membership cache settings.
# The API:
GET /api/name-services/cache/group-membership/settings
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/group-membership/settings?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "8a1a8730-2036-11ec-8457-005056bbcfdb",
      "name": "vs43"
    "enabled": true,
    "ttl": "PT1H"
    "svm": {
      "uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef",
      "name": "vs34"
    "enabled": true,
    "ttl": "PT5M"
"num_records": 2
Retrieving group-membership cache settings for a given SVM
The following example shows how to use the cache group-membership settings GET endpoint to retrieve group-membership cache settings for a given SVM.
# The API:
GET /api/name-services/cache/group-membership/settings/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/group-membership/settings/dc458b2f-2035-11ec-bfe2-005056bb6bef" -H "accept: application/hal+json"
# The response:
"svm": {
  "name": "vs34"
"enabled": true,
"ttl": "PT1H"
Updating a group-membership cache setting
The following example shows how to use the cache group-membership settings PATCH endpoint to update a group-membership setting.
# The API:
PATCH /api/name-services/cache/group-membership/settings/{svm.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/unix-user/settings/02c9e252-41be-11e9-81d5-00a0986138f9" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"enabled\": \"false\" }"
