Manage network IP subnets
Manage network IP subnets to configure, retrieve, update, and delete subnet information within your cluster. Use these endpoints to handle subnet operations efficiently, ensuring proper network configuration and management.
Overview
The following operations are supported:
Creation: POST network/ip/subnets
Collection Get: GET network/ip/subnets
Instance Get: GET network/ip/subnets/{uuid}
Instance Patch: PATCH network/ip/subnets/{uuid}
Instance Delete: DELETE network/ip/subnets/{uuid}
Retrieving IP subnet information
The IP subnets GET API retrieves and displays relevant information pertaining to the subnets configured in the cluster. The response can contain a list of multiple subnets or a specific subnet.
Retrieving all subnets in the cluster
The following example shows the list of all subnets configured in a cluster.
# The API:
/api/network/ip/subnets
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/subnets" -H "accept: application/hal+json"
# The response:
"records": [
"uuid": "451d8d99-582c-11ec-8572-005056acd597",
"name": "Subnet-002",
"href": "/api/network/ip/subnets/451d8d99-582c-11ec-8572-005056acd597"
"uuid": "615b722f-5795-11ec-8572-005056acd597",
"name": "Subnet-001",
"href": "/api/network/ip/subnets/615b722f-5795-11ec-8572-005056acd597"
"num_records": 2,
"href": "/api/network/ip/subnets"
Retrieving a specific subnet
The following example shows the response when a specific subnet is requested. This is equivalent to fields=*, which returns most of the fields. The system returns an error when there is no subnet with the requested UUID.
# The API:
/api/network/ip/subnets/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/subnets/451d8d99-582c-11ec-8572-005056acd597" -H "accept: application/hal+json"
# The response:
"ipspace": {
"uuid": "6f62c691-5780-11ec-8572-005056acd597",
"name": "Default",
"href": "/api/network/ipspaces/6f62c691-5780-11ec-8572-005056acd597"
"broadcast_domain": {
"uuid": "9a1dce3b-5780-11ec-8572-005056acd597",
"name": "Default",
"href": "/api/network/ethernet/broadcast-domains/9a1dce3b-5780-11ec-8572-005056acd597"
"subnet": {
"address": "10.2.1.0",
"netmask": "24",
"family": "ipv4"
"gateway": "10.2.1.1",
Retrieving all the fields for a specific subnet
The following example shows the response when all the fields for a specific subnet are requested, returning everything that fields=* returns plus the IP ranges and count fields. The system returns an error when there is no subnet with the requested UUID.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ip/subnets/451d8d99-582c-11ec-8572-005056acd597?fields=**" -H "accept: application/hal+json"
# The response:
"ipspace": {
"name": "Default",
"name": "Default",
"subnet": {
"netmask": "24",
"family": "ipv4"
"ip_ranges": [
"start": "10.2.1.10",
"end": "10.2.1.22",
"family": "ipv4"
"start": "10.2.1.101",
"end": "10.2.1.200",
"family": "ipv4"
"available_ip_ranges": [
"end": "10.2.1.22",
"family": "ipv4"
"family": "ipv4"
"total_count": 113,
"used_count": 0,
"available_count": 113,
"href": "/api/network/ip/subnets/451d8d99-582c-11ec-8572-005056acd597?fields=**"
Creating IP subnets
You can use the IP subnets POST API to create IP subnets as shown in the following examples.
Creating an IP subnet using the minimum number of parameters.
The following example shows the record returned after the creation of an IP subnet.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/network/ip/subnets" -H "accept: application/hal+json" -d '{ "name": "Subnet-003", "broadcast_domain": { "uuid": "6577524b-5863-11ec-8981-005056a7077f" }, "subnet": { "address": "10.3.0.0", "netmask": "16" } }'
# The response:
# The result:
curl -X GET "https://<mgmt-ip>/api/network/ip/subnets?name=Subnet-003&fields=**" -H "accept: application/hal+json"
"records": [
"uuid": "79ff5a5e-59b7-11ec-8981-005056a7077f",
"ipspace": {
"uuid": "36569d0f-5863-11ec-8981-005056a7077f",
"name": "Default",
"href": "/api/network/ipspaces/36569d0f-5863-11ec-8981-005056a7077f"
"uuid": "6577524b-5863-11ec-8981-005056a7077f",
"name": "Default",
"href": "/api/network/ethernet/broadcast-domains/6577524b-5863-11ec-8981-005056a7077f"
"subnet": {
"netmask": "16",
"family": "ipv4"
"total_count": 0,
"used_count": 0,
"available_count": 0,
"href": "/api/network/ip/subnets/79ff5a5e-59b7-11ec-8981-005056a7077f?fields=**"
"num_records": 1,
"href": "/api/network/ip/subnets?name=Subnet-003&fields=**"
Creating an IP subnet using all parameters.
The following example shows the record returned after the creation of an IP subnet setting all parameters.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/network/ip/subnets" -H "accept: application/hal+json" -d '{ "name": "Subnet-004", "ipspace": { "name": "Default", "uuid": "36569d0f-5863-11ec-8981-005056a7077f" }, "broadcast_domain": { "name": "Default", "uuid": "6577524b-5863-11ec-8981-005056a7077f" }, "subnet": { "address": "10.4.1.0", "netmask": "24" }, "gateway": "10.4.1.1", "ip_ranges": [ { "start": "10.4.1.30", "end": "10.4.1.39" }, { "start": "10.4.1.150", "end": "10.4.1.229" } ], "fail_if_lifs_conflict": "false" }'
# The response:
# The result:
curl -X GET "https://<mgmt-ip>/api/network/ip/subnets?name=Subnet-004&fields=**" -H "accept: application/hal+json"
"records": [
"uuid": "0e0a19e7-59ba-11ec-8981-005056a7077f",
"ipspace": {
"name": "Default",
"name": "Default",
"subnet": {
"netmask": "24",
"family": "ipv4"
"ip_ranges": [
"end": "10.4.1.39",
"family": "ipv4"
"end": "10.4.1.229",
"family": "ipv4"
"end": "10.4.1.39",
"family": "ipv4"
"family": "ipv4"
"total_count": 90,
"used_count": 0,
"available_count": 90,
"href": "/api/network/ip/subnets/0e0a19e7-59ba-11ec-8981-005056a7077f?fields=**"
"num_records": 1,
"href": "/api/network/ip/subnets?name=Subnet-004&fields=**"
Updating IP subnets
You can use the IP subnets PATCH API to update the attributes of an IP subnet.
Updating the name of an IP subnet
The following example shows how the PATCH request changes the name.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/network/ip/subnets/0e0a19e7-59ba-11ec-8981-005056a7077f" -H "accept: application/hal+json" -d '{ "name": "Subnet-004-NewName" }'
# The response:
# The result:
curl -X GET "https://<mgmt-ip>/api/network/ip/subnets/0e0a19e7-59ba-11ec-8981-005056a7077f?fields=name" -H "accept: application/hal+json"
"name": "Subnet-004-NewName",
"href": "/api/network/ip/subnets/0e0a19e7-59ba-11ec-8981-005056a7077f"
Updating the ip_ranges of an IP subnet
The following example shows how the PATCH request updates the ip_ranges.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/network/ip/subnets/0e0a19e7-59ba-11ec-8981-005056a7077f" -H "accept: application/hal+json" -d '{ "ip_ranges": [ { "start": "10.4.1.20", "end": "10.4.1.239" } ] }'
# The response:
# The result:
curl -X GET "https://<mgmt-ip>/api/network/ip/subnets/0e0a19e7-59ba-11ec-8981-005056a7077f?fields=ip_ranges" -H "accept: application/hal+json"
"ip_ranges": [
"end": "10.4.1.239",
"family": "ipv4"
Deleting IP subnets
You can use the IP subnets DELETE API to delete an IP subnet.
Example
Deleting an IP subnet
The following DELETE request deletes a specific network IP subnet.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/network/ip/subnets/0e0a19e7-59ba-11ec-8981-005056a7077f"
# The response:
# The result:
curl -X GET "https://<mgmt-ip>/api/network/ip/subnets/0e0a19e7-59ba-11ec-8981-005056a7077f" -H "accept: application/hal+json"
"error": {
"code": "4",
"target": "uuid"
