Manage SAML default metadata configuration
Overview
This API is used to manage relevant information about the SAML default metadata configuration in the cluster. The POST request creates a SAML default metadata configuration if there is none present. The DELETE request removes the SAML default metadata configuration. Various responses are shown in the examples below.
Retrieving the SAML default metadata configuration in the cluster
The following output shows the SAML default metadata configuration in the cluster.
# The API:
/api/security/authentication/cluster/saml-sp/default-metadata
# The call:
curl -X GET "https://<mgmt-ip>/api/security/authentication/cluster/saml-sp/default-metadata" -H "accept: application/hal+json"
# The response:
"host": "172.21.74.181",
"certificate": {
"ca": "cluster-1",
"serial_number": "180E3331A0DC5A19",
"common_name": "cluster-1"
"scope": "cluster",
"href": "/api/security/authentication/cluster/saml-sp/default-metadata"
Creating the SAML default metadata configuration in the cluster
The following output shows how to create the SAML default metadata in the cluster.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/security/authentication/cluster/saml-sp/default-metadata?return_records=true" -H "accept: application/hal+json" -d '{ "host": "172.21.74.181", "certificate": { "ca": "cluster1", "serial_number": "156F10C3EB4C51C1" }}'
Deleting the SAML default metadata configuration in the cluster
# The API: /api/security/authentication/cluster/saml-sp/default-metadata # The call: curl -X DELETE "https://<mgmt-ip>/api/security/authentication/cluster/saml-sp/default-metadata/"
