Manage share-level ACL
Configure and manage share-level access control lists (ACLs) on CIFS shares to secure file and folder access over a network. These endpoints help you define permissions for Windows or UNIX users and groups, ensuring proper user access based on share-level ACL checks.
Overview
Access to files and folders can be secured over a network by configuring share access control lists (ACLs) on CIFS shares. Share-level ACLs can be configured by using either Windows users and groups or UNIX users and groups. A share-level ACL consists of a list of access control entries (ACEs). Each ACE contains a user or group name and a set of permissions that determines user or group access to the share, regardless of the security style of the volume or qtree containing the share.
When an SMB user tries to access a share, ONTAP checks the share-level ACL to determine whether access should be granted. A share-level ACL only restricts access to files in the share; it never grants more access than the file level ACLs.
Creating a CIFS share ACL
To create a share ACL for a CIFS share, use the following API. Note the return_records=true query parameter used to obtain the newly created entry in the response.
# The API:
POST /api/protocols/cifs/shares{svm.uuid}/{share}/acls
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/sh1/acls?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"permission\": \"no_access\", \"type\": \"windows\", \"user_or_group\": \"root\"}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"user_or_group": "root",
"type": "windows",
"permission": "no_access",
"sid": "S-1-1-0"
Retrieving all CIFS shares ACLs for a specific CIFS share for a specific SVM in the cluster
# The API:
GET /api/protocols/cifs/shares/{svm.uuid}/{share}/acls
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/sh1/acls?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "000c5cd2-ebdf-11e8-a96e-0050568ea3cb",
"name": "vs1"
"share": "sh1",
"user_or_group": "Everyone",
"type": "windows",
"permission": "full_control",
"sid": "S-1-1-0"
"svm": {
"name": "vs1"
"share": "sh1",
"type": "windows",
"sid": "S-1-1-0"
"num_records": 2
Retrieving a CIFS share ACLs for a user or a group of type Windows or type UNIX on a CIFS share for a specific SVM
# The API:
GET /api/protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/sh1/acls/everyone/windows" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1"
"share": "sh1",
"user_or_group": "everyone",
"type": "windows",
"sid": "S-1-1-0"
Updating a CIFS share ACLs of a user or group on a CIFS share for a specific SVM
The CIFS share ACL being modified is identified by the UUID of its SVM, the CIFS share name, user or group name and the type of the user or group.
# The API:
PATCH /api/protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/sh1/acls/everyone/windows" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"permission\": \"no_access\"}"
Removing a CIFS share ACLs of a user or group on a CIFS Share for a specific SVM
The CIFS share ACL being removed is identified by the UUID of its SVM, the CIFS share name, user or group name and the type of the user or group.
# The API:
DELETE /api/protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/sh1/acls/everyone/windows" -H "accept: application/json"
