REST API reference
Update an S3 audit configuration for an SVM
PATCH /protocols/audit/{svm.uuid}/object-store
Introduced In: 9.10
Updates an S3 audit configuration for an SVM.
Important notes
  • events - Not specifying either data or management is equivalent to setting it to false.
  • vserver object-store-server audit modify
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
enabled
boolean
Specifies whether or not auditing is enabled on the SVM.
events
events
log
s3_log
log_path
string
The audit log destination path where consolidated audit logs are stored.
Example request
  "log": {
    "format": "string",
    "retention": {
      "duration": "P4DT12H30M5S"
    "rotation": {
      "schedule": {
        "days": [
          "integer"
        "hours": [
          "integer"
        "minutes": [
          "integer"
        "months": [
          "integer"
        "weekdays": [
          "integer"
  "log_path": "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
140902401
Failed to create an audit configuration for the SVM.
140902402
Audit configuration is already present.
140902402
Audit configuration is already enabled.
140902403
Failed to create staging volume.
140902415
Failed to modify an audit configuration because no audit configuration exists for SVM.
140902416
Failed to modify audit configuration for SVM.
140902422
Final consolidation is in progress, audit delete failed.
140902423
Failed to delete the audit configuration for the SVM.
140902425
Audit configuration is not available for disabling.
140902430
Audit configuration is not available for enabling.
140902431
Audit enable failed, audit configuration already enabled for the SVM.
140902432
Final consolidation is in progress, audit enable failed.
140902445
Audit disable failed, audit configuration does not exist for the SVM.
140902446
Audit configuration is already disabled.
140902446
140902456
The specified log_path does not exist.
140902457
The log_path must be a directory.
140902458
The log_path must be a canonical path in the SVM's namespace.
140902459
The log_path cannot be empty.
140902460
Rotate size must be greater than or equal to 1024 KB.
140902461
The destination path must not contain a symbolic link.
140902470
The log_path exceeds a maximum supported length of characters.
140902471
The log_path contains an unsupported read-only (DP/LS) volume.
140902472
The log_path is not a valid destination for the SVM.
140902474
The log_path contains an unsupported Snaplock volume.
140902478
The log_path validation failed.
140902478
The log_path cannot be accessed for validation.
140902479
No other fields can be specified when "enabled" is specified.
140902490
Audit configuration is absent for rotate.
140902491
Failed to rotate audit log.
140902492
Cannot rotate audit log, auditing is not enabled for this SVM.
Also see the table of common errors in the Response body overview section of this documentation. ONTAP Error Response Codes
262186
Field "log.retention.duration" cannot be used with field "log.retention.count"
9699340
SVM UUID lookup failed
9699407
Additional fields are provided
events
data
boolean
Data events
management
boolean
Management events
string
retention
count
integer
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with "duration".
duration
string
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with "count".
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days
array[integer]
Specifies the day of the month schedule to rotate audit log. Leave empty for all.
hours
array[integer]
Specifies the hourly schedule to rotate audit log. Leave empty for all.
minutes
array[integer]
Specifies the minutes schedule to rotate the audit log.
months
array[integer]
Specifies the months schedule to rotate audit log. Leave empty for all.
weekdays
array[integer]
Specifies the weekdays schedule to rotate audit log. Leave empty for all.
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now
boolean
Manually rotates the audit logs. Optional in PATCH only. Not available in POST.
schedule
audit_schedule
size
integer
Rotates logs based on log size in bytes.
s3_log
format
string
Format in which the logs are generated by the consolidation process. Possible values are:
  • json - ONTAP-specific Json log format.
    • Default value: 1
    • enum: ["json"]
    • Introduced in: 9.10
    • x-nullable: true
retention
retention
rotation
rotation
svm
name
string
uuid
string
s3_audit
Auditing for NAS events is a security measure that enables you to track and log certain S3 events on SVMs.
enabled
boolean
events
events
log
s3_log
log_path
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
