REST API reference
Update an S3 bucket configuration for an SVM
Updates the configuration of an S3 bucket for a storage virtual machine (SVM). Use this endpoint to modify various aspects of the bucket, such as policies, versioning, and access controls.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/buckets/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Updates the S3 bucket configuration of an SVM.
Important notes
  • The following fields can be modified for a bucket:
    • comment - Any information related to the bucket.
    • size - Bucket size.
    • policy - An access policy for resources (buckets and objects) that defines their permissions. New policies are created after existing policies are deleted. To retain any of the existing policy statements, you need to specify those statements again. Policy conditions can also be modified using this API.
    • qos_policy - A QoS policy for buckets.
    • audit_event_selector - Audit policy for buckets. None can be specified for both access and permission to remove audit event selector.
    • versioning_state - Versioning state for buckets.
    • nas_path - NAS path to which the NAS bucket corresponds to.
    • retention.default_period - Specifies the duration of default-retention applicable for objects on the object store bucket.
    • cors - Specifying CORS rules enables the bucket to service the cross-origin requests. New CORS rules are created after existing rules are deleted. To retain any of the existing rules, you need to specify those CORS rules again. To remove all the existing CORS rules, specify an empty CORS rules list.
    • snapshot_policy - Snapshot policy for the bucket.
    • is_consistent_etag - Return a consistent ETag for NAS buckets.
  • vserver object-store-server bucket modify
  • vserver object-store-server bucket policy statement modify
  • vserver object-store-server bucket policy-statement-condition modify
  • vserver object-store-server bucket cors-rule create
  • vserver object-store-server bucket cors-rule delete
uuid
string
path
True
The unique identifier of the bucket.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
Event selector allows you to specify access and permission types to audit.
comment
string
Can contain any additional information about the bucket being created or modified.
cors
cors
Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully.
encryption
encryption
is_consistent_etag
boolean
Specifies whether the NAS bucket returns a consistent ETag across different S3 requests.
lifecycle_management
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
logical_used_size
integer
Specifies the bucket logical used size up to this point. This field cannot be set using the PATCH method.
nas_path
string
Specifies the NAS path to which the nas bucket corresponds to.
policy
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
protection_status
protection_status
Specifies attributes of bucket protection.
qos_policy
qos_policy
Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
retention
retention
Specifies the retention mode and default retention period configured on the bucket.
role
string
Specifies the role of the bucket. This field cannot be set in a POST method.
size
integer
Specifies the bucket size in bytes; ranges from 190MB to 62PB.
snapshot_policy
snapshot_policy
Specifies the bucket snapshot policy.
svm
svm
type
string
Specifies the bucket type. Valid values are "s3"and "nas". This field cannot be set using the PATCH method.
uuid
string
Specifies the unique identifier of the bucket. This field cannot be specified in a POST or PATCH method.
versioning_state
string
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state.
volume
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted. This field cannot be set in a POST method.
Example request
  "audit_event_selector": {
    "access": "string",
    "permission": "string"
  "comment": "S3 bucket.",
  "cors": {
    "rules": [
        "allowed_headers": [
          "x-amz-request-id"
        "allowed_methods": [
          "PUT",
          "DELETE"
        "allowed_origins": [
          "http://www.example.com"
        "expose_headers": [
          "x-amz-date"
        "id": "string",
        "max_age_seconds": 1024
  "is_nas_path_mutable": true,
  "lifecycle_management": {
    "rules": [
        "expiration": {
          "object_age_days": 100,
          "object_expiry_date": "2039-09-22 20:00:00 -0400"
        "svm": {
          "name": "svm1",
        "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
  "logical_used_size": 0,
  "nas_path": "/",
  "policy": {
    "statements": [
        "actions": [
          "GetObject",
          "PutObject",
          "DeleteObject",
          "ListBucket"
        "conditions": [
            "delimiters": [
            "max_keys": [
              1000
            "operator": "ip_address",
            "prefixes": [
              "pref"
            "source_ips": [
              "1.1.1.1",
              "1.2.2.0/24"
            "usernames": [
              "user1"
        "effect": "allow",
        "principals": [
          "user1",
          "group/grp1",
          "nasgroup/group1"
        "resources": [
          "bucket1",
          "bucket1/*"
        "sid": "FullAccessToUser1"
  "qos_policy": {
    "max_throughput": [
      "900KB/s",
      "500MB/s",
      "120GB/s",
      "5000IOPS",
      "5000IOPS,500KB/s",
      "2500IOPS,100MB/s",
      "1000IOPS,25MB/s"
    "max_throughput_iops": 10000,
    "max_throughput_mbps": 500,
    "min_throughput": [
      "900KB/s",
      "500MB/s",
      "120GB/s",
      "5000IOPS",
      "5000IOPS,500KB/s",
      "2500IOPS,100MB/s",
      "1000IOPS,25MB/s"
    "min_throughput_iops": 2000,
    "min_throughput_mbps": 500,
    "name": "performance",
  "retention": {
    "default_period": "P10Y"
  "role": "string",
  "size": 819200000,
  "snapshot_policy": {
    "name": "default-1weekly",
    "uuid": "3675af31-431c-12fa-114a-20675afebc12"
  "svm": {
    "name": "svm1",
  "type": "s3",
  "uuid": "string",
  "versioning_state": "enabled",
  "volume": {
    "name": "volume1",
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error code Message
92405778
"Failed to modify bucket "{bucket name}" for SVM "{svm.name}". Reason: {Reason for failure}. ";
92405846
"Failed to modify the object store volume. Reason: {Reason for failure}.";
92405811
"Failed to modify bucket "{bucket name}" for SVM "{svm.name}". Wait a few minutes and try the operation again.";
92405858
"Failed to "modify" the "bucket" because the operation is only supported on data SVMs.";
92405861
"The specified "{parameter field}", "{parameter value}", does not exist.";
92405863
"Failed to create access policies for bucket "{bucket name}". Reason: "Principal list can have a maximum of 10 entries.". Resolve all the issues and retry the operation.";
92405864
"An error occurs when deleting an access policy. The reason for failure is detailed in the error message.";
92405891
The resources specified in the access policy are not valid. Valid ways to specify a resource are *, <bucket-name>, <bucket-name>/…​/…​. Valid characters for a resource are 0-9, A-Z, a-z, _, +, comma, ;, :, =, ., &, @,?, (, ), single quote, *, !, - and $.
92405894
"Statements, principals and resources list can have a maximum of 10 entries.";
92405897
The principals specified in the access policy are not in the correct format. User name must be in between 1 and 64 characters. Valid characters for a user name are 0-9, A-Z, a-z, _, +, =, comma, ., @, and - .
92405898
"The SID specified in the access policy is not valid. Valid characters for a SID are 0-9, A-Z and a-z.";
92405940
"The specified condition key is not valid for operator "ip-address". Valid choices of keys for this operator: source-ips.";
92406014
"Failed to modify event selector for bucket "{bucket name}". If value of either access or permission is set to none, then the other must be set to none as well.";
92406032
"Modifying the NAS path for a NAS bucket is not supported.";
92406230
"The value for "retention.default_period" parameter for object store bucket "" cannot be greater than the maximum lock retention period set in the object store server for SVM "". Check the maximum allowed lock retention period present in the object store server for SVM "" and try the operation again."; //end row //start row
92406236 //end row //start row
"The value for "retention.default_period" parameter for object store bucket "" cannot be less than the minimum lock retention period set in the object store server for SVM "". Check the minimum allowed lock retention period present in the object store server for SVM "" and try the operation again."; //end row //start row
92406217 //end row //start row
"The specified "allowed_headers" is not valid because it contains more than one wild card ("*") character."; //end row //start row
92406224 //end row //start row
"A Cross-Origin Resource Sharing (CORS) rule must have an origin and HTTP method specified."; //end row //start row
92406222 //end row //start row
"Cannot specify Cross-Origin Resource Sharing (CORS) configuration for object store bucket "" on SVM "". Specifying such configuration is supported on object store volumes created in ONTAP 9.8 or later releases only."; //end row //start row
92406211 //end row //start row
"The specified method "DONE" is not valid. Valid methods are GET, PUT, DELETE, HEAD, and POST."; //end row //start row
92405863 //end row //start row
"Failed to create CORS rules for bucket "bb1". Reason: "Field "index" cannot be specified for this operation.". Resolve all the issues and retry the operation."; //end row //start row
92406228 //end row //start row
"Cannot exceed the maximum limit of 100 Cross-Origin Resource Sharing (CORS) rules per S3 bucket "" in SVM "".";; //end row
|Name |Type |Description
|href |string a|
[#_links] [.api-collapsible-fifth-title] _links [#aggregates] [.api-collapsible-fifth-title] aggregates
Aggregate
[cols=3*,options=header]
|name |string a|
|uuid |string a|
[#audit_event_selector] [.api-collapsible-fifth-title] audit_event_selector
|access |string a|Specifies read and write access types.
|permission |string a|Specifies allow and deny permission types.
[#rules] [.api-collapsible-fifth-title] rules
Information about the CORS rule of an S3 bucket.
|allowed_headers |array[string] a|An array of HTTP headers allowed in the cross-origin requests.
|allowed_methods |array[string] a|An array of HTTP methods allowed in the cross-origin requests.
|allowed_origins |array[string] a|List of origins from where a cross-origin request is allowed to originate from for the S3 bucket.
|expose_headers |array[string] a|List of extra headers sent in the response that customers can access from their applications.
|id |string a|Bucket CORS rule identifier. The length of the name can range from 0 to 256 characters.
|max_age_seconds |integer a|The time in seconds for your browser to cache the preflight response for the specified resource.
[#cors] [.api-collapsible-fifth-title] cors
|rules |array[rules] a|Specifies an object store bucket CORS rule.
[#encryption] [.api-collapsible-fifth-title] encryption
|enabled |boolean a|Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. This field cannot be set in a POST or PATCH method.
[#abort_incomplete_multipart_upload] [.api-collapsible-fifth-title] abort_incomplete_multipart_upload
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
|after_initiation_days |integer a|Number of days of initiation after which uploads can be aborted.
[#expiration] [.api-collapsible-fifth-title] expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
|expired_object_delete_marker |boolean a|Cleanup object delete markers.
|object_age_days |integer a|Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date.
|object_expiry_date |string a|Specific date from when objects can expire. This cannot be used with object_age_days.
[#non_current_version_expiration] [.api-collapsible-fifth-title] non_current_version_expiration
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
|new_non_current_versions |integer a|Number of latest non-current versions to be retained.
|non_current_days |integer a|Number of days after which non-current versions can be deleted.
[#object_filter] [.api-collapsible-fifth-title] object_filter
Specifies a way to filter objects within a bucket.
|prefix |string a|A prefix that is matched against object-names within a bucket.
|size_greater_than |integer a|Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
|size_less_than |integer a|Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
|tags |array[string] a|An array of key-value paired tags of the form or <tag=value>.
[#svm] [.api-collapsible-fifth-title] svm
Specifies the name of the SVM where this bucket exists.
|name |string a|The name of the SVM. This field cannot be specified in a PATCH method.
|uuid |string a|The unique identifier of the SVM. This field cannot be specified in a PATCH method.
Information about the lifecycle management rule of a bucket.
|abort_incomplete_multipart_upload |abort_incomplete_multipart_upload a|Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
|enabled |boolean a|Specifies whether or not the associated rule is enabled.
|expiration |expiration a|Specifies a way to perform expiration action on filtered objects within a bucket.
|non_current_version_expiration |non_current_version_expiration a|Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
|svm |svm a|Specifies the name of the SVM where this bucket exists.
|uuid |string a|Specifies the unique identifier of the bucket.
[#lifecycle_management] [.api-collapsible-fifth-title] lifecycle_management
|rules |array[rules] a|Specifies an object store lifecycle management policy. This field cannot be set using the PATCH method.
[#s3_bucket_policy_condition] [.api-collapsible-fifth-title] s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
|delimiters |array[string] a|An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
|max_keys |array[integer] a|An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
|operator |string a|Condition operator that is applied to the specified condition key.
|prefixes |array[string] a|An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
|source_ips |array[string] a|An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
|usernames |array[string] a|An array of usernames that a current user in the context is evaluated against using the condition operators.
[#s3_bucket_policy_statement] [.api-collapsible-fifth-title] s3_bucket_policy_statement
Specifies information about a single access permission.
|actions |array[string] a|
|conditions |array[s3_bucket_policy_condition] a|Specifies bucket policy conditions.
|effect |string a|Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
|principals |array[string] a|
|resources |array[string] a|
|sid |string a|Specifies the statement identifier used to differentiate between statements. The sid length can range from 1 to 256 characters and can only contain the following combination of characters 0-9, A-Z, and a-z. Special characters are not valid.
[#policy] [.api-collapsible-fifth-title] policy
|statements |array[s3_bucket_policy_statement] a|Specifies bucket access policy statement.
[#destination] [.api-collapsible-fifth-title] destination
|is_cloud |boolean a|Specifies whether a bucket is protected within the Cloud.
|is_external_cloud |boolean a|Specifies whether a bucket is protected on external Cloud providers.
|is_ontap |boolean a|Specifies whether a bucket is protected within ONTAP.
  • Default value: 1
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
[#protection_status] [.api-collapsible-fifth-title] protection_status
|destination |destination a|
|is_protected |boolean a|Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud. This field cannot be set in a POST method.
  • Default value: 1
  • readOnly: 1
  • x-nullable: true
[#qos_policy] [.api-collapsible-fifth-title] qos_policy
|max_throughput |string a|Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
|max_throughput_iops |integer a|Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
|max_throughput_mbps |integer a|Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
|min_throughput |string a|Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
|min_throughput_iops |integer a|Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH.
|min_throughput_mbps |integer a|Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH.
|name |string a|The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
|uuid |string a|The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
[#retention] [.api-collapsible-fifth-title] retention
|default_period |string a|Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported.
[#snapshot_policy] [.api-collapsible-fifth-title] snapshot_policy
|name |string a|Specifies the name of the snapshot policy.
|uuid |string a|Specifies the unique identifier of the snapshot policy.
[#volume] [.api-collapsible-fifth-title] volume
|name |string a|The name of the volume. This field cannot be specified in a PATCH method.
|uuid |string a|Unique identifier for the volume. This corresponds to the instance-uuid that is exposed in the CLI and ONTAPI. It does not change due to a volume move.
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
[#s3_bucket_svm] [.api-collapsible-fifth-title] s3_bucket_svm
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
|audit_event_selector |audit_event_selector a|Event selector allows you to specify access and permission types to audit.
|comment |string a|Can contain any additional information about the bucket being created or modified.
|cors |cors a|Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully.
|encryption |encryption a|
|is_consistent_etag |boolean a|Specifies whether the NAS bucket returns a consistent ETag across different S3 requests.
|lifecycle_management |lifecycle_management a|Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
|logical_used_size |integer a|Specifies the bucket logical used size up to this point. This field cannot be set using the PATCH method.
|nas_path |string a|Specifies the NAS path to which the nas bucket corresponds to.
|policy |policy a|A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
|protection_status |protection_status a|Specifies attributes of bucket protection.
|qos_policy |qos_policy a|Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
|retention |retention a|Specifies the retention mode and default retention period configured on the bucket.
|role |string a|Specifies the role of the bucket. This field cannot be set in a POST method.
|size |integer a|Specifies the bucket size in bytes; ranges from 190MB to 62PB.
|snapshot_policy |snapshot_policy a|Specifies the bucket snapshot policy.
|svm |svm a|SVM, applies only to SVM-scoped objects.
|type |string a|Specifies the bucket type. Valid values are "s3"and "nas". This field cannot be set using the PATCH method.
|uuid |string a|Specifies the unique identifier of the bucket. This field cannot be specified in a POST or PATCH method.
|versioning_state |string a|Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state.
|volume |volume a|Specifies the FlexGroup volume name and UUID where the bucket is hosted. This field cannot be set in a POST method.
[#job_link] [.api-collapsible-fifth-title] job_link
|uuid |string a|The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
[#error_arguments] [.api-collapsible-fifth-title] error_arguments
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
