REST API reference
Update the Barbican KMS configuration
PATCH /security/barbican-kms/{uuid}
Introduced In: 9.17
Updates the Barbican KMS configuration.
Optional properties
  • application_cred_id - New credentials used to verify the application's identity to the Barbican KMS. You must provide both application_cred_id and application_cred_secret to update the credentials.
  • application_cred_secret - New credentials secret used to verify the application's identity to the Barbican KMS. You must provide both application_cred_id and application_cred_secret to update the credentials.
  • proxy_type - Type of proxy (http/https) if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • verify - Verify the identity of the Barbican KMS?
  • verify_host - Verify the identity of the Barbican KMS host name?
  • timeout - Connection timeout in seconds.
  • security key-manager external barbican update-credentials
  • security key-manager external barbican update-config
uuid
string
path
True
Barbican KMS UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
_links
_links
application_cred_id
string
Keystone application credentials ID required to access the specified Barbican KMS.
string
Keystone application credentials secret required to access the specified Barbican KMS. It is not audited.
barbican_reachability
Indicates whether the Barbican KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET request or an instance GET request unless it is explicitly requested using the field's query parameter or GET for all advanced properties is enabled.
enabled
boolean
Indicates whether the configuration is enabled.
proxy_host
string
Proxy host name.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
Indicates whether or not the SVM key encryption key (KEK) is available cluster wide. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
timeout
integer
uuid
string
A unique identifier of the Barbican KMS.
verify
boolean
Verify the identity of the Barbican KMS.
verify_host
boolean
Verify the identity of the Barbican KMS host name.
Example request
  "application_cred_id": "63e3cb77f84f42b7a0395a3efb7636f9",
  "application_cred_secret": "secret",
  "barbican_reachability": {
    "code": "346758",
    "message": "Barbican KMS is not reachable from all nodes - <reason>.",
    "reachable": ""
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "scope": "string",
  "state": {
    "cluster_state": "",
    "code": "346758",
    "message": "Top-level internal key encryption key is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
  "timeout": 60,
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65539223
Failed to check the health of the Barbican Key Management Service.
65539814
Failed to update the Barbican Key Management Service configuration because the "application-cred-secret" field is invalid or was not provided.
65539815
Failed to update the Barbican Key Management Service configuration because the "application-cred-id" field is invalid or was not provided.
65539832
Specified Barbican Key Management Service configuration does not exist.
65539841
Both "application_cred_id" and "application_cred_secret" are required.
string
code
string
Code corresponding to the error message. Returns 0 if Barbican KMS is reachable from all nodes in the cluster.
message
string
Set to the appropriate error message when 'reachable' is false.
reachable
boolean
Set to true if the Barbican KMS is reachable from all nodes of the cluster.
configuration
Security keystore object reference.
name
string
Name of the configuration.
uuid
string
Keystore UUID.
state
cluster_state
boolean
Set to true when an SVM-KEK is present on all nodes of the cluster.
code
string
Code corresponding to the status message. Returns a 0 if the SVM-KEK is available on all nodes in the cluster.
message
string
Error message returned when there's no SVM-KEK availability on the cluster.
svm
name
string
uuid
string
barbican
_links
_links
application_cred_id
string
string
enabled
boolean
proxy_host
string
Proxy host name.
proxy_password
string
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
state
state
timeout
integer
uuid
string
verify
boolean
verify_host
boolean
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
