REST API reference
Update a configured group role-mapping entry
PATCH /security/group/role-mappings/{group_id}/{ontap_role.name}
Introduced In: 9.16
Updates a configured group role-mapping.
  • security login group role-mapping modify
group_id
integer
path
True
Group ID.
  • format: int64
  • Max value: 4294967295
  • Min value: 1
ontap_role.name
string
path
True
Role name.
Request Body
Name Type Description
comment
string
Any comment regarding this group entry.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "comment": "string",
  "scope": "string"
Status: 200, Ok
Status: Default, Error
string
ontap_role
Role name.
name
string
Role name
group_role_mappings
comment
string
scope
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
