REST API reference
Create a Barbican KMS configuration for an SVM
Creates a Barbican Key Management Service (KMS) configuration for a specified Storage Virtual Machine (SVM). This setup is essential for integrating secure key management within your SVM environment.
HTTP method and endpoint
POST /security/barbican-kms
Introduced in
ONTAP 9.17
Usage notes
Creates a Barbican KMS configuration for the specified SVM.
Required properties
  • configuration.name - Name for the new Barbican configuration.
  • svm.uuid or svm.name - Existing SVM in which to create a Barbican KMS.
  • key_id - Barbican key URL.
  • keystone_url - Keystone authentication URL.
  • application_cred_id - Keystone authentication application ID with access to the Barbican KMS.
  • application_cred_secret- Application credentials secret to authenticate the application credentials ID with Keystone.
Optional properties
  • proxy_type - Type of proxy (http/https) if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • verify - Verify the identity of the Barbican KMS?
  • verify_host - Verify the identity of the Barbican KMS host name?
  • timeout - Connection timeout in seconds.
  • security key-manager external barbican create-config
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
application_cred_id
string
Keystone application credentials ID required to access the specified Barbican KMS.
string
Keystone application credentials secret required to access the specified Barbican KMS. It is not audited.
barbican_reachability
Indicates whether the Barbican KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET request or an instance GET request unless it is explicitly requested using the field's query parameter or GET for all advanced properties is enabled.
configuration
configuration
Security keystore object reference.
enabled
boolean
Indicates whether the configuration is enabled.
key_id
string
Key Identifier URL of the Barbican KMS key encryption key. Must be an HTTPS URL.
keystone_url
string
Keystone URL for the access token. Must be an HTTPS URL.
proxy_host
string
Proxy host name.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
Indicates whether or not the SVM key encryption key (KEK) is available cluster wide. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
svm
timeout
integer
uuid
string
A unique identifier of the Barbican KMS.
verify
boolean
Verify the identity of the Barbican KMS.
verify_host
boolean
Verify the identity of the Barbican KMS host name.
Example request
  "application_cred_id": "63e3cb77f84f42b7a0395a3efb7636f9",
  "application_cred_secret": "secret",
  "barbican_reachability": {
    "code": "346758",
    "message": "Barbican KMS is not reachable from all nodes - <reason>.",
    "reachable": ""
  "configuration": {
    "name": "default",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
  "key_id": "https://172.29.58.184:9311/v1/secrets/5c610a4f-ea97-44b5-8682-f4daeafa9647",
  "keystone_url": "https://keystoneip:5000/v3/auth/tokens",
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "scope": "string",
  "state": {
    "cluster_state": "",
    "code": "346758",
    "message": "Top-level internal key encryption key is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
  "svm": {
    "name": "svm1",
  "timeout": 60,
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
1115127
Package MT_EK_MGMT is not licensed in the cluster.
65539805
Failed to create a Barbican Key Management Service configuration because the "application-cred-secret" field is invalid or was not provided.
65539806
Barbican Key Management Service (KMS) cannot be configured because not all nodes in the cluster are running an effective cluster version of 9.17 or later to support the Barbican KMS feature.
65539807
Barbican Key Management Service is not supported for the admin SVM.
65539808
Failed to create the specified Barbican Key Management Service configuration because a Barbican Key Management Service configuration with the same name already exists.
65539809
Barbican Key Management Service is not supported in MetroCluster configurations.
65539810
Failed to create a Barbican Key Management Service configuration because the "key-id" field is invalid or was not provided. The URI scheme must be HTTPS.
65539811
Failed to create a Barbican Key Management Service configuration because the "keystone-url" field is invalid or was not provided. The URI scheme must be HTTPS.
65539835
Failed to create a Barbican Key Management Service configuration because the "application-cred-id" field cannot be empty.
string
code
string
Code corresponding to the error message. Returns 0 if Barbican KMS is reachable from all nodes in the cluster.
message
string
Set to the appropriate error message when 'reachable' is false.
reachable
boolean
Set to true if the Barbican KMS is reachable from all nodes of the cluster.
configuration
name
string
Name of the configuration.
uuid
string
Keystore UUID.
state
cluster_state
boolean
Set to true when an SVM-KEK is present on all nodes of the cluster.
code
string
Code corresponding to the status message. Returns a 0 if the SVM-KEK is available on all nodes in the cluster.
message
string
Error message returned when there's no SVM-KEK availability on the cluster.
svm
name
string
uuid
string
barbican
_links
_links
application_cred_id
string
string
configuration
configuration
enabled
boolean
key_id
string
keystone_url
string
proxy_host
string
Proxy host name.
proxy_password
string
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
state
state
svm
svm
timeout
integer
uuid
string
verify
boolean
verify_host
boolean
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
