REST API reference
Create a new file with the supplied data
Creates a new file, directory, or symlink using the provided data. This operation is typically used when you need to add new resources to the file system.
HTTP method and endpoint
POST /storage/volumes/{volume.uuid}/files/{path}
Introduced in
ONTAP 9.8
Usage notes
Creates a new file with the supplied data, a new directory or a new symlink.
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Relative path of a new file, directory or symlink. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided.
byte_offset
integer
query
False
Indicates the number of bytes into the file to begin writing. Use "-1" to append (default). Note that the byte-offset field is only supported for writing to a new or existing file, which requires specifying the Content-Type as 'multipart/form-data'.
overwrite
boolean
query
False
If false, and the file exists, the write will fail. Default is false.
stream_name
string
query
False
Name of stream associated with the file to write data to.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
accessed_time
string
Last access time of the file in date-time format.
analytics
analytics
Additional file system analytics information summarizing all descendants of a directory.
This property is only populated if file system analytics is enabled on the containing volume.
In the context of the records property of a file_info_response , analytics objects will only include properties that may vary between elements within the collection. For example, the analytics objects will not contain histogram labels, since the same histogram labels are used for all elements within the collection. The invariant information is instead available via the analytics property of the file_info_response . This avoids an excessive amount of duplicated information when a GET /storage/volumes/{volume.uuid}/files/{path} call returns a large collection.
bytes_used
integer
The actual number of bytes used on disk by this file. If byte_offset and length parameters are specified, this will return the bytes used by the file within the given range.
changed_time
string
Last time data or attributes changed on the file in date-time format.
constituent
constituent
creation_time
string
Creation time of the file in date-time format.
group_id
integer
The integer ID of the group of the file owner.
hard_links_count
integer
The number of hard links to the file.
inode_generation
integer
Inode generation number.
inode_number
integer
The file inode number.
is_empty
boolean
Specifies whether or not a directory is empty. A directory is considered empty if it only contains entries for "." and "..". This element is present if the file is a directory. In some special error cases, such as when the volume goes offline or when the directory is moved while retrieving this info, this field might not get set.
is_junction
boolean
Returns "true" if the directory is a junction.
is_snapshot
boolean
Returns "true" if the directory is a snapshot.
is_vm_aligned
boolean
Returns true if the file is vm-aligned. A vm-aligned file is a file that is initially padded with zero-filled data so that its actual data starts at an offset other than zero. The amount by which the start offset is adjusted depends on the vm-align setting of the hosting volume.
modified_time
string
Last data modification time of the file in date-time format.
name
string
Name of the file.
owner_id
integer
The integer ID of the file owner.
path
string
Path of the file.
target
string
The relative or absolute path contained in a symlink, in the form /.
type
string
Type of the file.
unique_bytes
integer
Number of bytes uniquely held by this file. If byte_offset and length parameters are specified, this will return bytes uniquely held by the file within the given range.
unix_permissions
integer
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write), and 1 (execute). The first digit selects the set user ID(4), set group ID (2), and sticky (1) attributes. The second digit selects permissions for the owner of the file; the third selects permissions for other users in the same group; the fourth selects permissions for other users not in the group.
volume
volume
Example request
  "accessed_time": "2019-06-12 11:00:16 -0400",
  "analytics": {
    "by_accessed_time": {
      "bytes_used": {
        "aged_data_metric": 15.23,
        "labels": [
          "2019-07",
          "2019-06",
          "2019-05",
          "2019",
          "2018",
          "--2017",
          "unknown"
        "newest_label": "2019-07",
        "oldest_label": "2019-07",
        "percentages": [
          0.1,
          11.24,
          0.18,
          15.75,
          0.75,
          83.5,
          0
        "values": [
          15925248,
          1735569408,
          27672576,
          2430595072,
          116105216,
          12889948160,
          0
    "by_modified_time": {
      "bytes_used": {
        "labels": [
          "2019-07",
          "2019-06",
          "2019-05",
          "2019",
          "2018",
          "--2017",
          "unknown"
        "percentages": [
          0.1,
          11.24,
          0.18,
          15.75,
          0.75,
          83.5,
          0
        "values": [
          15925248,
          1735569408,
          27672576,
          2430595072,
          116105216,
          12889948160,
          0
    "bytes_used": 15436648448,
    "file_count": 21134,
    "report_time": "string",
    "subdir_count": 35
  "bytes_used": 4096,
  "changed_time": "2019-06-12 11:00:16 -0400",
  "constituent": {
    "name": "fg__0001",
  "creation_time": "2019-06-12 11:00:16 -0400",
  "fill_enabled": true,
  "group_id": 30,
  "hard_links_count": 1,
  "inode_generation": 214753547,
  "inode_number": 1695,
  "is_junction": "",
  "is_snapshot": "",
  "is_vm_aligned": "",
  "modified_time": "2019-06-12 11:00:16 -0400",
  "name": "string",
  "overwrite_enabled": true,
  "owner_id": 54738,
  "path": "string",
  "target": "string",
  "type": "file",
  "unique_bytes": 4096,
  "volume": {
    "name": "volume1",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
917505
The SVM does not exist.
917525
The volume in the symlink path does not exist in the SVM.
917698
Volume (vol name) in SVM (vserver) is not mounted in the namespace.
917698
The volume in the symlink path is not mounted in the namespace.
918235
A volume with UUID {volume.uuid} was not found.
918757
The specified clone parent volume with UUID {volume.uuid} does not exist.
6488064
This command is not supported.
6488065
The volume in the symlink path is invalid.
6488066
Mounting the unjunctioned volume in the symlink path failed.
6488069
Internal file error.
6488084
Failed to create {path} because the "unix_permissions" field was not specified.
6488085
Failed to create {path} because the "type" field was not specified.
6488118
File exists.
8257536
This operation is not supported for the system volume specified in the symlink path.
8257541
Failed to compute the SVM identification from this content.
8257542
This operation is not supported for the administrative SVM.
9437549
This operation is not allowed on SVMs with Infinite Volume.
13172837
This operation is not permitted because the SVM is locked for a migrate operation.
111411203
Failed to get the volume file system analytics report on the volume.
111411204
Internal error. Failed to retrieve the volume file system analytics report on the volume.
111411207
Volume file system analytics is not supported on volumes that contain LUNs.
111411209
Volume file system analytics is not supported on FlexCache volumes.
111411210
Volume file system analytics is not supported on audit staging volumes.
111411211
Volume file system analytics is not supported on object store server volumes.
111411212
Volume file system analytics is not supported on SnapMirror destination volumes.
111411215
Internal error. Volume file system analytics report timed out for volume volume.name in SVM svm.name.
111411216
Enabling or disabling volume file system analytics is not supported on individual FlexGroup constituents.
111411217
Volume file system analytics is not supported on SnapLock volumes.
111411230
Volume file system analytics is not supported on volumes that contain NVMe namespaces.
111412203
Volume file system analytics is not enabled on the volume.
string
bytes_used
Number of bytes used on-disk, broken down by date of last access.
aged_data_metric
number
A score summarizing how old the data is. A higher value means the data is older.
labels
array[string]
Labels for this histogram
newest_label
string
Each label indicates the period of time the corresponding data is associated with. A label can take one of the following forms:<ul> a partial date in an extended ISO8601 representation an interval between partial dates in an extended ISO8601 representation, where "--" is used to separate the beginning and end of the interval the string literal "unknown"
</ul>For partial dates and partial date intervals where components of a date are unspecified, the label allows for any valid normalized values the unspecified components might take. For example, the label "2017" allows for any time within the year 2017. Essentially, this is the fully specified interval 2017-01-01T00:00:00—​2017-12-31T23:59:59. Similarly, the interval "2018-05—​2018-07" allows for any time within the months of May, June, and July in 2018, corresponding to the fully specified interval 2018-05-01T00:00:00—​2018-07-31T23:59:59.
The following extensions to ISO8601 are used:<ul> Quarters may be specified. The form yyyy-Qq is used to represent the qth quarter of the year yyyy. Q1 consists of the months January, February, and March; Q2 consists of April, May, and June; Q3 consists of July, August, and September; Q4 consists of October, November, and December. For example, the label "2019-Q2" represents the second quarter of the year 2019, which corresponds to the interval 2019-04-01T00:00:00—​2019-06-30T23:59:59. Either the beginning or end of an interval may be omitted. When the beginning is omitted, the interval includes points in time arbitrarily far in the past. When the end is omitted, the interval includes points in time through the end of the current week.
</ul>The "unknown" label tracks data that could not be associated with any other time period. This usually occurs when the data was at some point associated with a time in the future.
oldest_label
string
percentages
array[number]
Percentages for this histogram
values
array[integer]
Values for this histogram
by_accessed_time
File system analytics information, broken down by date of last access.
bytes_used
bytes_used
bytes_used
Number of bytes used on-disk, broken down by date of last modification.
aged_data_metric
number
labels
array[string]
newest_label
string
oldest_label
string
percentages
array[number]
values
array[integer]
by_modified_time
File system analytics information, broken down by date of last modification.
bytes_used
bytes_used
analytics
by_accessed_time
by_accessed_time
by_modified_time
by_modified_time
bytes_used
integer
file_count
integer
Number of descendants
incomplete_data
boolean
Returns true if data collection is incomplete for this directory tree.
report_time
string
The date and time analytics information was collected.
subdir_count
integer
Number of sub directories
constituent
name
string
FlexGroup volume constituent name.
uuid
string
FlexGroup volume constituent UUID.
qos_policy
The QoS policy for the file. Both traditional and adaptive QoS policies are supported. If both qos_policy.uuid and qos_policy.name properties are specified in the same request, they must refer to the same QoS policy. To remove the file from a QoS policy, set the property qos_policy.name in a PATCH request to an empty string "" or "none".
Note Files which are in use as a LUN cannot be assigned to a QoS policy, instead use PATCH on /storage/luns to assign a QoS policy for such files.
Note that a QoS policy can be set on a file, or a file's volume, but not on both.
name
string
The name of the QoS policy. To remove the file from a QoS policy, set this property to an empty string "" or set it to "none" in a PATCH request.
uuid
string
The unique identifier of the QoS policy. Valid in PATCH.
volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
file_info
Information about a single file.
accessed_time
string
analytics
analytics
bytes_used
integer
changed_time
string
constituent
constituent
creation_time
string
group_id
integer
hard_links_count
integer
inode_generation
integer
inode_number
integer
is_empty
boolean
is_junction
boolean
is_snapshot
boolean
is_vm_aligned
boolean
modified_time
string
name
string
Name of the file.
owner_id
integer
path
string
Path of the file.
target
string
type
string
Type of the file.
unique_bytes
integer
unix_permissions
integer
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
