Protocols active-directory svm.uuid preferred-domain-controllers endpoint overview
Overview
You can use this API to display the preferred DC configuration of an SVM.
Retrieving all the preferred DC configurations of an SVM
The preferred DC GET endpoint retrieves all the configurations for a specific SVM.
Retrieving all fields for all the preferred DC configurations of an SVM
# The API:
GET /api/protocols/active-directory/{svm.uuid}/preferred-domain-controllers
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/active-directory/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?fields=*" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "1226670c-abc9-11eb-8de3-0050568eb0c4",
"name": "svm1"
"fqdn": "host1",
"server_ip": "4.4.4.4"
"svm": {
"name": "svm1"
"fqdn": "host2",
"server_ip": "11.11.11.11"
"num_records": 2
Retrieving the preferred DC configuration of a specific SVM, "fqdn" and "server_ip"
# The API:
GET /api/protocols/active-directory/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/active-directory/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/host1/4.4.4.4" -H "accept: application/json"
# The response:
"svm": {
"name": "svm1"
"fqdn": "host1",
Creating a new preferred DC configuration
The preferred DC POST endpoint creates a new configuration. Both bulk and instance POST is supported.
Creating a single preferred DC configuration
# The API:
POST /api/protocols/active-directory/{svm.uuid}/preferred-domain-controllers
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/active-directory/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers?skip_config_validation=true&return_records=false" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"fqdn\": \"testing.com\", \"server_ip\": \"1.1.1.1\"}"
Deleting an existing preferred DC configuration
The preferred DC DELETE endpoint deletes an existing configuration. Both bulk and instance delete is supported.
Deleting the preferred DC configuration of a specific SVM, "fqdn" and "server_ip"
# The API:
DELETE /api/protocols/active-directory/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/active-directory/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/sample/4.4.4.4"
Deleting the preferred DC configurations of a specific SVM and "fqdn"
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/active-directory/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?fqdn=sampl"
Deleting all preferred DC configurations of a specific SVM
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/active-directory/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?fqdn=*"
Deleting the preferred DC configurations of a specific SVM, "fqdn" and set of "server_ips"
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/active-directory/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?fqdn=sample&server_ip=3.3.3.3|4.4.4.4|1.1.1.1|2.2.2.2"
Deleting the preferred DC configurations of a specific SVM and set of "server_ips"
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/active-directory/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?server_ip=3.3.3.3|4.4.4.4|1.1.1.1|2.2.2.2"
