REST API reference
Protocols fpolicy svm.uuid connections endpoint overview
Overview
This API is used to display and update connection status information for external FPolicy servers. You must keep the following in mind while using these endpoints:
  • If the passthrough_read field is set to true in a GET collection call, only FPolicy passthrough-read connections are returned.
  • If the passthrough_read field is not provided or set to false in a GET collection call, only FPolicy server connections are returned.
Retrieving the FPolicy server connections for all SVMs in the cluster
# The API:
GET /protocols/fpolicy/{svm.uuid}/connections
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/*/connections?passthrough_read=false&fields=*&return_records=true" -H  "accept: application/json"
# The Response:
"records": [
    "node": {
      "uuid": "8ca36b68-c501-11eb-b82c-0050568e5902",
      "name": "user-vsim4"
    "svm": {
      "uuid": "9f738ac5-c502-11eb-b82c-0050568e5902",
      "name": "vs1"
    "policy": {
      "name": "p1"
    "server": "192.168.137.78",
    "state": "disconnected",
    "update_time": "2021-06-17T16:05:15+05:30",
    "disconnected_reason": {
      "message": "No local lif present to connect to FPolicy server.",
      "code": 9305
    "type": "primary"
    "node": {
    "svm": {
      "name": "vs1"
    "policy": {
      "name": "p2"
    "server": "192.168.136.38",
      "code": 9305
    "type": "primary"
    "node": {
    "svm": {
      "uuid": "b6df362b-c502-11eb-b82c-0050568e5902",
      "name": "vs2"
    "policy": {
      "name": "pol1"
    "server": "192.168.129.146",
      "code": 9305
    "type": "primary"
"num_records": 3
Retrieving all FPolicy passthrough read connections for all SVMs in the cluster
# The API:
# The Call:
curl-X GET "https://<mgmt-ip>/api/protocols/fpolicy/*/connections?passthrough_read=true&fields=*&return_records=true&return_timeout=15"
# The Response:
"records": [
    "node": {
      "uuid": "55693090-c7c8-11eb-a07a-0050568ebc01",
      "name": "user-vsim3",
    "svm": {
      "uuid": "a69e938d-c7ca-11eb-a07a-0050568ebc01",
      "name": "vs2",
    "policy": {
      "name": "pol1",
    "session_uuid": "2410d348-c7cb-11eb-a07a-0050568ebc01",
    "state": "connected",
    "node": {
    "svm": {
      "name": "vs2",
    "policy": {
      "name": "pol2",
    "session_uuid": "288f7002-c7cb-11eb-a07a-0050568ebc01",
"num_records": 2,
Retrieving the FPolicy server connections for a specific SVM
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/9f738ac5-c502-11eb-b82c-0050568e5902/connections?passthrough_read=false&fields=*&return_records=true" -H  "accept: application/json"
# The Response:
"records": [
    "node": {
    "svm": {
      "name": "vs1"
    "policy": {
      "name": "p1"
      "code": 9305
    "type": "primary"
    "node": {
    "svm": {
      "name": "vs1"
    "policy": {
      "name": "p2"
      "code": 9305
    "type": "primary"
"num_records": 2
Retrieving a specific FPolicy server connection
# The API:
GET /protocols/fpolicy/{svm.uuid}/connections/{node.uuid}/{policy.name}/{server}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/9f738ac5-c502-11eb-b82c-0050568e5902/connections/8ca36b68-c501-11eb-b82c-0050568e5902/p1/192.168.137.78" -H  "accept: application/json"
# The Response:
"node": {
"svm": {
  "name": "vs1"
"policy": {
  "name": "p1"
  "code": 9305
"type": "primary"
Updating the FPolicy server connection
# The API:
PATCH /protocols/fpolicy/{svm.uuid}/connections/{node.uuid}/{policy.name}/{server}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/fpolicy/9f738ac5-c502-11eb-b82c-0050568e5902/connections/8ca36b68-c501-11eb-b82c-0050568e5902/p1/192.168.137.78" -H  "accept: application/json"
