REST API reference
Security barbican-kms endpoint overview
Overview
Barbican Key Management Services (KMS) is a key management service that provides a secure store for encryption keys. This feature allows ONTAP to securely protect its encryption keys using Barbican KMS. Before you can use Barbican KMS with ONTAP, you must provide ONTAP with the necessary details to allow ONTAP to communicate with the deployed Barbican application. These details include the key ID URL, Keystone authentication URL, and the application credentials ID and secret. The property barbican_reachability is considered an advanced property and is populated only when explicitly requested.
Creating an inactive Barbican configuration for an SVM
The example Barbican configuration is created for a specific SVM but is not enabled. Note the return_records=true query parameter can be used to return the newly created key-manager keystore configuration.
# The API:
POST /api/security/barbican-kms
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/barbican-kms' -H 'accept: application/hal+json' -H 'Content-Type: application/json' -d '{ "svm": { "name": "barbican_svm" }, "configuration": {"name": "myConfiguration"}, "application_cred_id": "app1", "application_cred_secret": "secret1", "key_id": "https://sample.keyid.com:9311/v1/secrets/5c610a4f-ea97-44b5-8682-f4daeafa9647/", "keystone_url": "https://sample.keystone.com:5000/v3/auth/tokens" }'
# The response:
"job": {
  "uuid": "5a208fb0-fa58-11ef-8c9f-005056bbeee5",
      "href": "/api/cluster/jobs/5a208fb0-fa58-11ef-8c9f-005056bbeee5"
Listing all Barbican configurations
The following example shows how to retrieve a list of all created Barbican configurations.
# The API:
GET /api/security/barbican-kms
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/barbican-kms'
# The response:
"records": [
    "configuration": {
      "name": "myConfiguration",
      "uuid": "5a134975-fa58-11ef-8c9f-005056bbeee5"
    "uuid": "5a134975-fa58-11ef-8c9f-005056bbeee5",
        "href": "/api/security/barbican-kms/5a134975-fa58-11ef-8c9f-005056bbeee5"
"num_records": 1,
    "href": "/api/security/barbican-kms"
Retrieving a specific Barbican configuration
The following example shows how to retrieve information for a specific Barbican configuration.
# The API:
GET /api/security/barbican-kms/{uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/barbican-kms/5a134975-fa58-11ef-8c9f-005056bbeee5?fields=*'
# The response:
"configuration": {
"scope": "svm",
"svm": {
  "uuid": "ec8e0954-fa10-11ef-8c9f-005056bbeee5",
"keystone_url": "https://sample.keystone.com:5000/v3/auth/tokens",
"proxy_type": "https",
"proxy_host": "",
"proxy_port": 0,
"proxy_username": "",
"verify": true,
"verify_host": true,
"enabled": false,
"timeout": 10,
Retrieving an advanced property for a specific Barbican configuration
The following example shows how to retrieve an advanced property for a specific Barbican configuration.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/barbican-kms/f72098a2-e908-11ea-bd56-005056bb4222?fields=barbican_reachability'
# The response:
"configuration": {
  "uuid": "f72098a2-e908-11ea-bd56-005056bb4222"
"uuid": "f72098a2-e908-11ea-bd56-005056bb4222",
"barbican_reachability": {
  "reachable": true,
  "message": "",
  "code": "0"
    "href": "/api/security/barbican-kms/f72098a2-e908-11ea-bd56-005056bb4222"
Updating the application credentials ID and secret for a specific Barbican configuration
The following example shows how to update the application credentials for a specific Barbican configuration.
# The API:
PATCH /api/security/barbican-kms/{uuid}
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/barbican-kms/f72098a2-e908-11ea-bd56-005056bb4222/' -d '{"application_cred_id": "app345", "application_cred_secret" : "secret"}'
# The response:
"job": {
  "uuid": "921ee66a-fa5a-11ef-8c9f-005056bbeee5",
      "href": "/api/cluster/jobs/921ee66a-fa5a-11ef-8c9f-005056bbeee5"
Enabling a Barbican configuration
The newly created Barbican configuration is inactive by default. Use the REST API PATCH method "/api/security/key-stores/{uuid}" to enable the configuration.
Restoring keys
The following example shows how to restore keys for a specific Barbican configuration.
# The API:
POST /api/security/barbican-kms/{uuid}/restore
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/barbican-kms/f72098a2-e908-11ea-bd56-005056bb4222/restore'
# The response:
"job": {
  "uuid": "e89e7283-2c49-11f0-831c-005056bb33a5",
      "href": "/api/cluster/jobs/e89e7283-2c49-11f0-831c-005056bb33a5"
Rekey the internal key
The following example shows how to rekey the internal key based on a specific Barbican configuration.
# The API:
POST /api/security/barbican-kms/{uuid}/rekey-internal
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/barbican-kms/f72098a2-e908-11ea-bd56-005056bb4222/rekey-internal'
# The response:
"job": {
