REST API reference
View a WebAuthn global setting entry
Overview
This API endpoint retrieves WebAuthn global settings for the cluster or SVM. Specify the owner UUID and the unique identifier for the cluster or SVM to retrieve the WebAuthn global settings for the cluster or SVM.
Retrieving the WebAuthn global settings for the cluster or SVM
# The API:
GET "/api/security/webauthn/global-settings/{owner.uuid}"
# The call:
curl -k https://<mgmt-ip>/api/security/webauthn/global-settings/d49de271-8c11-11e9-8f78-005056bbf6ac
