View all WebAuthn supported algorithms
Overview
This API endpoint retrieves the list of supported algorithms for WebAuthn authentication.
Retrieving the list of supported algorithms
This endpoint retrieves all of the supported algorithms for WebAuthn authentication. The following table lists the supported algorithms:
| Algorithm ID | Algorithm Name | Description |
-7 |
ES256 |
ECDSA w/ SHA-256 |
-35 |
ES384 |
ECDSA w/ SHA-384 |
-257 |
RS256 |
RSASSA-PKCS1-v1_5 using SHA-256 |
# The API: GET "/api/security/webauthn/supported-algorithms" # The call to retrieve the list of supported algorithms: curl -k https://<mgmt-ip>/api/security/webauthn/supported-algorithms
