REST API reference
View and update NFS client settings
Adjust NFS client settings across your cluster with these endpoints. Set cache idle times to optimize performance and ensure timely removal of inactive entries.
Overview
This cluster-wide API is used to set the maximum cache idle time (client_retention_interval) for the connected-clients cache. If a client connected to NFS server is idle for longer than than the maximum cache idle time, the entry will be removed. The update_interval value will change when the client_retention_interval is changed. The update interval represents the interval between the cleaning happens. If the value of client_retention_interval is set to 60hrs the connected client entry will stay there for 60 hours and after that it will get removed. If the value of update_interval is 8 hours then the cache will be refreshed once every 8 hours.
Example
Retrieves connected-client cache settings information
# The API:
GET /api/protocols/nfs/connected-client-settings
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/nfs/connected-client-settings?return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
"client_retention_interval": "P7D",
"update_interval": "PT8H"
Updating connected-client cache settings
# The API:
PATCH /api/protocols/nfs/connected-client-settings
# The call:
curl -d "@test_cache_settings_patch.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/connected-client-settings"
test_cache_settings_patch.txt(body):
