Manage the BlueXP cloud service
Overview
You can use this API to ping the BlueXP cloud service. The POST operation retrieves the details about service reachability, configurability, and ping latency.
Performing a ping operation
You can perform a ping operation by issuing a POST request on /cluster/mediator-ping. Parameters are provided in the body of the POST request. There is only one required parameter.
Required configuration fields
These fields are always required for any POST /cluster/mediator-ping request.
type- Specifies the type of the mediator.
POST request body for a ping to the BlueXP cloud service.
# API /api/cluster/mediator-ping
POST request body from a file
ping_post_body.txt:
"type": "cloud"
curl -X POST https://<mgmt-ip>/api/cluster/mediator-ping -d "@ping_post_body.txt"
Inline POST request body
curl -X POST https://<mgmt-ip>/api/cluster/mediator-ping -d '{"type":"cloud"}'
POST request response
HTTP/1.1 200 OK
Cache-Control: no-cache,no-store,must-revalidate
Connection: close
Date: Mon, 03 Mar 2025 16:40:20 GMT
Server: libzapid-httpd
Vary: Accept-Encoding,Origin
Content-Length: 69
Content-Type: application/hal+json
Client-Date: Mon, 03 Mar 2025 16:40:20 GMT
Client-Peer: 10.235.144.44:80
Client-Response-Num: 1
Content-Security-Policy: default-src 'self'; script-src 'self' 'unsafe-inline'; style-src 'self' 'unsafe-inline'; img-src 'self' data:; frame-ancestors: 'self'
X-Content-Type-Options: nosniff
"reachable": true,
"latency_ms": 50,
"configurable": true,
"high_latency": false,
"proxy_configured": true,
"proxy_used": true,
"timeout_occurred": false
