REST API reference
Manage cluster software packages
Overview
You can use this API to retrieve the software packages for a cluster.
Retrieving cluster software packages information
The following example shows how to retrieve the ONTAP software packages in a cluster.
# The API:
/api/cluster/software/packages
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/software/packages?return_records=true&return_timeout=15" -H "accept: application/hal+json"
# The response:
"records": [
    "version": "9.7.0",
        "href": "/api/cluster/software/packages/9.7.0"
    "version": "9.5.0",
        "href": "/api/cluster/software/packages/9.5.0"
"num_records": 2,
    "href": "/api/cluster/software/packages"
Retrieves the software package information for a particular version
The following example shows how to retrieve the details of a given cluster software package.
# The API:
/api/cluster/software/packages/{version}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/software/packages/9.7.0" -H "accept: application/hal+json"
# The response:
"version": "9.7.0",
"create_time": "2018-05-21T10:06:59+05:30",
Deleting a cluster software package
The following example shows how to delete a package from the cluster. You need to provide the package version that you want to delete. The software package delete creates a job to perform the delete operation.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/cluster/software/packages/9.6.0" -H "accept: application/hal+json"
# The response:
"job": {
  "uuid": "f587d316-5feb-11e8-b0e0-005056956dfc",
      "href": "/api/cluster/jobs/f587d316-5feb-11e8-b0e0-005056956dfc"
The call to delete the package returns the job UUID, including a HAL link to retrieve details about the job. The job object includes a state field and a message to indicate the progress of the job. When the job is complete and the application is fully created, the message indicates success and the job state field is set to success.
# The API:
/api/cluster/jobs/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/jobs/f587d316-5feb-11e8-b0e0-005056956dfc" -H "accept: application/hal+json"
# The response:
"description": "DELETE /api/cluster/software/packages/9.6.0",
"state": "success",
"message": "success",
"code": 0,
