REST API reference
Retrieve FC fabric zones
GET /network/fc/fabrics/{fabric.name}/zones
Introduced In: 9.11
Retrieves the zones of the active zoneset of a Fibre Channel fabric.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • members
  • network fcp zone show
fabric.name
string
path
True
The WWN of the primary switch of the Fibre Channel fabric.
name
string
query
False
Filter by name
cache.age
string
query
False
Filter by cache.age
cache.is_current
boolean
query
False
Filter by cache.is_current
cache.update_time
string
query
False
Filter by cache.update_time
members.name
string
query
False
Filter by members.name
members.type
string
query
False
Filter by members.type
cache.maximum_age
string
query
False
The maximum age of data in the Fibre Channel fabric cache before it should be refreshed from the fabric. The default is 15 minutes.
  • Default value: 1
  • format: iso8601
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[fc_zone]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "cache": {
        "age": "PT3M30S",
        "update_time": "string"
      "fabric": {
        "name": "10:00:d1:d2:d3:d4:d5:d6"
      "members": [
          "name": "10:00:12:34:56:78:9a:bc",
          "type": "port_name"
      "name": "zone1"
Status: Default
ONTAP Error Response Codes
Error Code Description
5373982
An invalid WWN was specified. The length is incorrect.
5373983
An invalid WWN was specified. The format is incorrect.
5375053
The Fibre Channel fabric specified by name in the request URI was not found in the FC fabric cache.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cache
Properties of Fibre Chanel fabric cache.
age
string
The age of the Fibre Channel fabric data cache retrieved. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved. The value is in ISO 8601 duration format.
is_current
boolean
A boolean that indicates if the retrieved data is current relative to the cache.maximum_age value of the request. A value of true indicates that the data is no older than the requested maximum age. A value of false indicates that the data is older than the requested maximum age; if more current data is required, the caller should wait for some time for the cache update to complete and query the data again.
update_time
string
The date and time at which the Fibre Channel fabric data cache retrieved was last updated. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved.
fabric
A reference to a Fibre Channel fabric.
_links
_links
name
string
The world wide name (WWN) of the primary switch of the Fibre Channel (FC) fabric. This is used as a unique identifier for the FC fabric.
members
A Fibre Channel zone member.
name
string
The identifying property value of the zone member. The format of this value depends on the member type:
  • port_id: A zero-filled 6-digit hexadecimal value with a 0x prefer. Example: 0x0000A0.
  • port_name: A world-wide name. Example: 10:00:12:34:56:78:9a:bc.
  • domain_id_port: A domain ID and a port ID as decimal integers separated by a slash. Example: 1/2.
  • node_name: A world-wide name. Example: 10:00:11:22:33:44:55:66.
  • fabric_port_name: A world-wide name. Example: 10:00:ab:cd:ef:12:34:56.
The following types might not report a name:
  • interface
  • domain_interface
  • ip_address
  • symbolic_node_name
  • device_alias
type
string
The type of Fibre Channel zone member. This value should be used to interpret the contents of the name property.
fc_zone
A Fibre Channel zone.
_links
_links
cache
cache
fabric
fabric
members
array[members]
An array of Fibre Channel zone members.
name
string
The name of the Fibre Channel zone.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
