REST API reference
Retrieve CIFS shares
GET /protocols/cifs/shares
Introduced In: 9.6
Retrieves CIFS shares.
  • vserver cifs share show
  • vserver cifs share properties show
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
offline_files
string
query
False
Filter by offline_files
  • Introduced in: 9.10
browsable
boolean
query
False
Filter by browsable
  • Introduced in: 9.13
allow_unencrypted_access
boolean
query
False
Filter by allow_unencrypted_access
  • Introduced in: 9.11
encryption
boolean
query
False
Filter by encryption
max_connections_per_share
integer
query
False
Filter by max_connections_per_share
  • Introduced in: 9.14
home_directory
boolean
query
False
Filter by home_directory
namespace_caching
boolean
query
False
Filter by namespace_caching
acls.type
string
query
False
Filter by acls.type
acls.user_or_group
string
query
False
Filter by acls.user_or_group
acls.permission
string
query
False
Filter by acls.permission
acls.win_sid_unix_id
string
query
False
Filter by acls.win_sid_unix_id
  • Introduced in: 9.16
vscan_profile
string
query
False
Filter by vscan_profile
continuously_available
boolean
query
False
Filter by continuously_available
show_snapshot
boolean
query
False
Filter by show_snapshot
oplocks
boolean
query
False
Filter by oplocks
access_based_enumeration
boolean
query
False
Filter by access_based_enumeration
change_notify
boolean
query
False
Filter by change_notify
name
string
query
False
Filter by name
  • maxLength: 80
  • minLength: 1
show_previous_versions
boolean
query
False
Filter by show_previous_versions
dir_umask
string
query
False
Filter by dir_umask
attribute_cache
boolean
query
False
Filter by attribute_cache
path
string
query
False
Filter by path
  • maxLength: 256
  • minLength: 1
unix_symlink
string
query
False
Filter by unix_symlink
file_umask
string
query
False
Filter by file_umask
no_strict_security
boolean
query
False
Filter by no_strict_security
  • Introduced in: 9.9
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
comment
string
query
False
Filter by comment
  • maxLength: 256
  • minLength: 1
force_group_for_create
string
query
False
Filter by force_group_for_create
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_share]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "acls": [
          "permission": "string",
          "type": "string",
          "user_or_group": "ENGDOMAIN\\ad_user",
          "win_sid_unix_id": "string"
      "comment": "HR Department Share",
      "dir_umask": "21",
      "file_umask": "21",
      "force_group_for_create": "string",
      "name": "HR_SHARE",
      "offline_files": "string",
      "path": "/volume_1/eng_vol/",
      "svm": {
        "name": "svm1",
      "unix_symlink": "string",
      "volume": {
        "name": "volume1",
      "vscan_profile": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
acls
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
type
string
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
  • windows - Windows user or group
  • unix_user - UNIX user
  • unix_group - UNIX group
user_or_group
string
Specifies the user or group name to add to the access control list of a CIFS share.
win_sid_unix_id
string
Windows SID/UNIX ID depending on access-control type.
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
cifs_share
CIFS share is a named access point in a volume. Before users and applications can access data on the CIFS server over SMB, a CIFS share must be created with sufficient share permission. CIFS shares are tied to the CIFS server on the SVM. When a CIFS share is created, ONTAP creates a default ACL for the share with Full Control permissions for Everyone.
_links
_links
boolean
If enabled, all folders inside this share are visible to a user based on that individual user access right; prevents the display of folders or other shared resources that the user does not have access to.
acls
array[acls]
boolean
Specifies whether or not the SMB2 clients are allowed to access the encrypted share.
attribute_cache
boolean
Specifies that connections through this share cache attributes for a short time to improve performance.
browsable
boolean
Specifies whether or not the Windows clients can browse the share.
change_notify
boolean
Specifies whether CIFS clients can request for change notifications for directories on this share.
comment
string
Specify the CIFS share descriptions.
boolean
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback. If the Vscan ONTAP feature is used, it is not supported in continuous availability (CA) shares.
  • Default value:
  • x-nullable: true
dir_umask
string
Directory Mode Creation Mask to be viewed as an octal number.
encryption
boolean
Specifies that SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share.
file_umask
string
File Mode Creation Mask to be viewed as an octal number.
string
Specifies that all files that CIFS users create in a specific share belong to the same group (also called the "force-group"). The "force-group" must be a predefined group in the UNIX group database. This setting has no effect unless the security style of the volume is UNIX or mixed security style.
home_directory
boolean
Specifies whether or not the share is a home directory share, where the share and path names are dynamic. ONTAP home directory functionality automatically offer each user a dynamic share to their home directory without creating an individual SMB share for each user. The ONTAP CIFS home directory feature enable us to configure a share that maps to different directories based on the user that connects to it. Instead of creating a separate shares for each user, a single share with a home directory parameters can be created. In a home directory share, ONTAP dynamically generates the share-name and share-path by substituting %w, %u, and %d variables with the corresponding Windows user name, UNIX user name, and domain name, respectively.
  • Default value:
  • readCreate: 1
  • x-nullable: true
integer
Maximum number of tree connections on share.
name
string
Specifies the name of the CIFS share that you want to create. If this is a home directory share then the share name includes the pattern as %w (Windows user name), %u (UNIX user name) and %d (Windows domain name) variables in any combination with this parameter to generate shares dynamically.
namespace_caching
boolean
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers.
no_strict_security
boolean
Specifies whether or not CIFS clients can follow a unix symlinks outside the share boundaries.
offline_files
string
Offline Files The supported values are:
  • none - Clients are not permitted to cache files for offline access.
  • manual - Clients may cache files that are explicitly selected by the user for offline access.
  • documents - Clients may automatically cache files that are used by the user for offline access.
  • programs - Clients may automatically cache files that are used by the user for offline access and may use those files in an offline mode even if the share is available.
oplocks
boolean
Specify whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations.
path
string
The fully-qualified pathname in the owning SVM namespace that is shared through this share. If this is a home directory share then the path should be dynamic by specifying the pattern %w (Windows user name), %u (UNIX user name), or %d (domain name) variables in any combination. ONTAP generates the path dynamically for the connected user and this path is appended to each search path to find the full Home Directory path.
  • example: /volume_1/eng_vol/
  • maxLength: 256
  • minLength: 1
  • x-nullable: true
boolean
Specifies that the previous version can be viewed and restored from the client.
show_snapshot
boolean
Specifies whether or not the snapshots can be viewed and traversed by clients.
svm
svm
unix_symlink
string
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
  • local - Enables only local symbolic links which is within the same CIFS share.
  • widelink - Enables both local symlinks and widelinks.
  • disable - Disables local symlinks and widelinks.
volume
volume
vscan_profile
string
Vscan File-Operations Profile The supported values are:
  • no_scan - Virus scans are never triggered for accesses to this share.
  • standard - Virus scans can be triggered by open, close, and rename operations.
  • strict - Virus scans can be triggered by open, read, close, and rename operations.
  • writes_only - Virus scans can be triggered only when a file that has been modified is closed.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
