REST API reference
Retrieve historical performance metrics for the iSCSI protocol service of an SVM for a specific time
GET /protocols/san/iscsi/services/{svm.uuid}/metrics/{timestamp}
Introduced In: 9.14
Retrieves historical performance metrics for the iSCSI protocol service of an SVM for a specific time.
svm.uuid
string
path
True
timestamp
string
path
True
The timestamp of the performance data.
  • format: date-time
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
svm
svm
throughput
throughput
timestamp
string
      "href": "/api/resourcelink"
  "duration": "PT15S",
  "iops": {
    "read": 200,
    "total": 1000,
    "write": 100
  "latency": {
    "read": 200,
    "total": 1000,
    "write": 100
  "status": "ok",
  "svm": {
  "throughput": {
    "read": 200,
    "total": 1000,
    "write": 100
  "timestamp": "2017-01-25 11:20:13 +0000"
Status: Default
ONTAP Error Response Codes
Error Code Description
8585947
No metrics are available for the requested object.
8586225
An unexpected error occurred retrieving metrics for the requested object.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
svm
uuid
string
throughput
read
integer
total
integer
write
integer
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
