REST API reference
Retrieve cluster network security certificate configuration
GET /security/cluster-network/certificates
Introduced In: 9.18
Retrieves the certificate configuration used for cluster network security.
  • 'security cluster-network certificate show'
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
certificate.name
string
query
False
Filter by certificate.name
certificate.uuid
string
query
False
Filter by certificate.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "certificate": {
        "name": "string",
      "node": {
        "name": "node1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
security_certificate_reference
Security certificate object reference
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
node_reference
_links
_links
name
string
uuid
string
records
Manages the cluster network security certificate configuration.
_links
_links
certificate
node
node_reference
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
