REST API reference
Retrieve all external-role-mapping entries
GET /security/external-role-mappings
Introduced In: 9.16
Retrieves all external-role-mapping entries.
  • security login external-role-mapping show
comment
string
query
False
Filter by comment
provider
string
query
False
Filter by provider
ontap_role.name
string
query
False
Filter by ontap_role.name
timestamp
string
query
False
Filter by timestamp
external_role
string
query
False
Filter by external_role
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[security_external_role_mapping]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "comment": "string",
      "external_role": "string",
      "ontap_role": {
        "name": "admin"
      "provider": "string",
      "timestamp": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
ontap_role
ONTAP role to map with the external identity role.
_links
_links
name
string
Role name
_links
self_link
comment
string
Any comment regarding this external-role-mapping entry.
external_role
string
External Identity provider role.
ontap_role
ontap_role
  • Introduced in: 9.16
provider
string
Type of the external identity provider.
timestamp
string
Date and time indicating when this external-role-mapping entry was created.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
