REST API reference
Retrieve the JIT privilege user configurations for an SVM
GET /security/jit-privilege-users/{owner.uuid}/{account.name}/{application}
Introduced In: 9.17
Retrieves the JIT privilege user configurations for an SVM.
  • security jit-privilege user show
owner.uuid
string
path
True
Used to identify a cluster or an SVM
account.name
string
path
True
The username.
application
string
path
True
The name of the application.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
account
account_reference
The name of the user.
application
string
comment
string
The description of the elevation rule.
end_time
string
The end date and time of the JIT privilege session in UTC.
jit_state
string
The current status of the rule: preactive, idle, or active.
jit_validity
string
The JIT validity period on this SVM for this user.
owner
owner
Owner name and UUID that uniquely identifies the JIT settings for a user.
role
role
The role the user will be elevated to.
session_validity
string
The session validity period on this SVM for this user.
start_time
string
The start date and time of the JIT privilege session in UTC.
  "account": {
        "href": "/api/resourcelink"
    "name": "joe.smith"
  "application": "string",
  "comment": "Comment text",
  "end_time": "2024-11-08 11:15:31 +0000",
  "jit_state": "active",
  "jit_validity": "P90D",
  "owner": {
    "name": "svm1",
  "role": {
    "name": "admin"
  "session_validity": "PT1H",
  "start_time": "2024-11-08 10:15:31 +0000"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
account_reference
_links
_links
name
string
User account
owner
_links
_links
name
string
uuid
string
role
_links
_links
name
string
Role name
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
