REST API reference
Retrieve information for SnapMirror relationships
GET /snapmirror/relationships
Introduced In: 9.6
Retrieves information for SnapMirror relationships whose destination endpoints are in the current SVM or the current cluster, depending on the cluster context.
  • snapmirror show
  • snapmirror list-destinations
Expensive properties
  • source.consistency_group_volumes.name
  • destination.consistency_group_volumes.name
  • svmdr_volumes.name
The following examples show how to retrieve the list of SnapMirror relationships and the list of SnapMirror destinations.
  1. Retrieving the list of SnapMirror relationships. This API must be run on the cluster containing the destination endpoint.
 GET "/api/snapmirror/relationships/"
  1. Retrieving the list of SnapMirror destinations on source. This must be run on the cluster containing the source endpoint.
 GET "/api/snapmirror/relationships/?list_destinations_only=true"
  1. Retrieving the relationship UUID of SnapMirror relationships with lag time greater than 2 days. This API must be run on the cluster containing the destination endpoint.
 GET "/api/snapmirror/relationships/?fields=uuid&lag_time=>P2DT"
  1. Retrieving the list of SnapMirror relationships with lag time less than 10 hours. This API must be run on the cluster containing the destination endpoint.
 GET "/api/snapmirror/relationships/?lag_time=<PT10H"
  1. Retrieving the list of constituent volumes for SVM DR Snapmirror relationships.
 GET "/api/snapmirror/relationships/?fields=svmdr_volumes.name"
</private>
boolean
query
False
Set to true to show relationships from the source only.
transfer.end_time
string
query
False
Filter by transfer.end_time
  • Introduced in: 9.9
transfer.uuid
string
query
False
Filter by transfer.uuid
transfer.bytes_transferred
integer
query
False
Filter by transfer.bytes_transferred
transfer.state
string
query
False
Filter by transfer.state
transfer.total_duration
string
query
False
Filter by transfer.total_duration
transfer.type
string
query
False
Filter by transfer.type
  • Introduced in: 9.14
transfer.last_updated_time
string
query
False
Filter by transfer.last_updated_time
state
string
query
False
Filter by state
restore
boolean
query
False
Filter by restore
policy.name
string
query
False
Filter by policy.name
policy.type
string
query
False
Filter by policy.type
policy.uuid
string
query
False
Filter by policy.uuid
source.cluster.name
string
query
False
Filter by source.cluster.name
  • Introduced in: 9.7
source.cluster.uuid
string
query
False
Filter by source.cluster.uuid
string
query
False
Filter by source.consistency_group_volumes.name
  • Introduced in: 9.8
source.path
string
query
False
Filter by source.path
source.luns.uuid
string
query
False
Filter by source.luns.uuid
  • Introduced in: 9.16
source.luns.name
string
query
False
Filter by source.luns.name
source.svm.name
string
query
False
Filter by source.svm.name
source.svm.uuid
string
query
False
Filter by source.svm.uuid
lag_time
string
query
False
Filter by lag_time
consistency_group_failover.error.arguments.message
string
query
False
Filter by consistency_group_failover.error.arguments.message
consistency_group_failover.error.arguments.code
string
query
False
Filter by consistency_group_failover.error.arguments.code
consistency_group_failover.error.code
string
query
False
Filter by consistency_group_failover.error.code
consistency_group_failover.error.message
string
query
False
Filter by consistency_group_failover.error.message
consistency_group_failover.state
string
query
False
Filter by consistency_group_failover.state
consistency_group_failover.status.message
string
query
False
Filter by consistency_group_failover.status.message
consistency_group_failover.status.code
string
query
False
Filter by consistency_group_failover.status.code
consistency_group_failover.type
string
query
False
Filter by consistency_group_failover.type
group_type
string
query
False
Filter by group_type
  • Introduced in: 9.11
master_bias_activated_site
string
query
False
Filter by master_bias_activated_site
destination.luns.uuid
string
query
False
Filter by destination.luns.uuid
destination.luns.name
string
query
False
Filter by destination.luns.name
destination.svm.name
string
query
False
Filter by destination.svm.name
destination.svm.uuid
string
query
False
Filter by destination.svm.uuid
string
query
False
Filter by destination.consistency_group_volumes.name
destination.cluster.name
string
query
False
Filter by destination.cluster.name
destination.cluster.uuid
string
query
False
Filter by destination.cluster.uuid
destination.path
string
query
False
Filter by destination.path
io_serving_copy
string
query
False
Filter by io_serving_copy
throttle
integer
query
False
Filter by throttle
last_transfer_type
string
query
False
Filter by last_transfer_type
preferred_site
string
query
False
Filter by preferred_site
exported_snapshot
string
query
False
Filter by exported_snapshot
identity_preservation
string
query
False
Filter by identity_preservation
unhealthy_reason.message
string
query
False
Filter by unhealthy_reason.message
unhealthy_reason.arguments
string
query
False
Filter by unhealthy_reason.arguments
unhealthy_reason.code
string
query
False
Filter by unhealthy_reason.code
svmdr_volumes.name
string
query
False
Filter by svmdr_volumes.name
  • Introduced in: 9.13
total_transfer_duration
string
query
False
Filter by total_transfer_duration
healthy
boolean
query
False
Filter by healthy
uuid
string
query
False
Filter by uuid
total_transfer_bytes
integer
query
False
Filter by total_transfer_bytes
backoff_level
string
query
False
Filter by backoff_level
transfer_schedule.name
string
query
False
Filter by transfer_schedule.name
transfer_schedule.uuid
string
query
False
Filter by transfer_schedule.uuid
last_transfer_network_compression_ratio
string
query
False
Filter by last_transfer_network_compression_ratio
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapmirror_relationship]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "backoff_level": "medium",
      "consistency_group_failover": {
        "error": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "message": "entry doesn't exist"
        "state": "string",
        "status": {
          "code": "string",
          "message": "string"
        "type": "string"
      "destination": {
        "cluster": {
          "name": "cluster1",
        "consistency_group_volumes": [
            "name": "volume1"
        "luns": {
          "name": "/vol/volume1/lun1",
        "path": "svm1:volume1",
        "svm": {
          "name": "svm1",
      "exported_snapshot": "string",
      "group_type": "consistency_group",
      "identity_preservation": "string",
      "io_serving_copy": "C1_sti85-vsim-ucs209a_cluster, C1_sti85-vsim-ucs209c_cluster",
      "lag_time": "PT8H35M42S",
      "last_transfer_network_compression_ratio": 61,
      "last_transfer_type": "initialize",
      "master_bias_activated_site": "C1_sti85-vsim-ucs209a_cluster",
      "policy": {
        "name": "Asynchronous",
        "type": "string",
      "preferred_site": "C1_sti85-vsim-ucs209a_cluster",
      "restore_to_snapshot": "string",
      "source": {
        "cluster": {
          "name": "cluster1",
            "name": "volume1"
        "luns": {
        "svm": {
          "name": "svm1",
      "state": "snapmirrored",
      "svmdr_volumes": [
          "name": "volume1"
      "throttle": 0,
      "total_transfer_bytes": 1098210312,
      "total_transfer_duration": "PT3M21S",
      "transfer": {
        "end_time": "2020-12-02 18:36:19 -0800",
        "last_updated_time": "2023-09-14 15:39:19 -0700",
        "state": "string",
        "total_duration": "PT28M41S",
        "type": "initialize",
      "transfer_schedule": {
        "name": "weekly",
      "unhealthy_reason": [
          "arguments": [],
          "code": "6621444",
          "message": "Failed to complete update operation on one or more item relationships."
          "arguments": [],
          "code": "6621445",
          "message": "Group Update failed"
Status: Default
ONTAP Error Response codes
Error code Description
13303825
Could not retrieve information for the SnapMirror policy type
13303817
Unknown value for the Snapmirror State
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
code
string
Argument code
message
string
Message argument
error
SnapMirror Consistency Group failover error message.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
status
code
string
Status code
message
string
SnapMirror Consistency Group failover status.
snapmirror_consistency_group_failover
SnapMirror Consistency Group failover information. The SnapMirror Consistency Group failover can be a planned or an unplanned operation. Only active SnapMirror Consistency Group failover operation progress can be monitored using this object. In case of an error during the failover operation, the property "consistency_group_failover.error" holds the reason for the error. ONTAP automatically retries any failed SnapMirror Consistency Group failover operation.
error
error
state
string
SnapMirror Consistency Group failover state.
status
status
type
string
SnapMirror Consistency Group failover type.
bucket_retention
Specifies the retention-mode and default retention period configured on the destination bucket.
default_period
string
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported.
mode
string
The lock mode of the bucket. compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. governance ‐ An administrator can delete a Governance bucket. no_lock ‐ Indicates the bucket does not support object locking.
storage_service
enabled
boolean
This property indicates whether to create the destination endpoint using storage service. This property is supported for Unified ONTAP destination endpoints only.
  • x-nullable: true
enforce_performance
boolean
Optional property to enforce storage service performance on the destination endpoint. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. This property is supported for Unified ONTAP destination endpoints only.
  • Default value:
  • x-nullable: true
name
string
Optional property to specify the storage service name for the destination endpoint. This property is considered when the property "create_destination.storage_service.enabled" is set to "true". When the property "create_destination.storage_service.enabled" is set to "true" and the "create_destination.storage_service.name" for the endpoint is not specified, then ONTAP selects the highest storage service available on the cluster to provision the destination endpoint. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. This property is supported for Unified ONTAP destination endpoints only.
  • enum: ["extreme", "performance", "value"]
  • Introduced in: 9.6
  • x-nullable: true
tiering
policy
string
Optional property to specify the destination endpoint's tiering policy when "create_destination.tiering.supported" is set to "true". This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. This property determines whether the user data blocks of the destination endpoint in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of the destination endpoint volume blocks increases if they are accessed frequently and decreases when they are not. all ‐ This policy allows tiering of both destination endpoint snapshots and the user transferred data blocks to the cloud store as soon as possible by ignoring the temperature on the volume blocks. This tiering policy is not applicable for Consistency Group destination endpoints or for synchronous relationships. auto ‐ This policy allows tiering of both destination endpoint snapshots and the active file system user data to the cloud store none ‐ Destination endpoint volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the destination endpoint volume snapshots not associated with the active file system. The default tiering policy is "snapshot_only" for a FlexVol volume and "none" for a FlexGroup volume. This property is supported for Unified ONTAP destination endpoints only.
  • enum: ["all", "auto", "none", "snapshot_only"]
  • x-nullable: true
supported
boolean
Optional property to enable provisioning of the destination endpoint volumes on FabricPool aggregates. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. Only FabricPool aggregates are used if this property is set to "true" and only non FabricPool aggregates are used if this property is set to "false". Tiering support for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. Note that in order to tier data, not only do the destination endpoint volumes need to support tiering by using FabricPools, the "create_destination.tiering.policy" must not be "none". A destination endpoint that uses FabricPools but has a tiering "policy" of "none" supports tiering but will not tier any data. This property is supported for Unified ONTAP destination endpoints only.
  • x-nullable: true
snapmirror_destination_creation
Use this object to provision the destination endpoint when establishing a SnapMirror relationship for a FlexVol volume, FlexGroup volume, SVM, Consistency Group or ONTAP S3 Bucket. Given a source endpoint, the destination endpoint is provisioned in the SVM specified in the "destination.path" property. While protecting an SVM, the SVM destination endpoint can only be provisioned on the local cluster. To provision the SVM destination endpoint use the optional "source.cluster.name" property to specify the remote cluster name or use the optional "source.cluster.uuid" property to specify the remote cluster UUID. When "create_destination.enabled" option is specified while making a POST for a SnapMirror relationship, the relationship can be automatically initialized by setting the "state" either to "snapmirrored" when the policy is of type "async" or to "in_sync" when the policy is of type "sync". The "destination.path" property must specify the destination endpoint path. For example, for FlexVol volume and FlexGroup volume, the "destination.path" can be specified as , for SVM data protection, the "destination.path" must be specified as <destination-svm-name:>, and for Consistency Group, the "destination.path" must be specified as <destination-svm-name:> along with the "destination.consistency_group_volumes" or "destination.luns" property to indicate the list of destination volumes or LUNs of type "DP" in the Consistency Group. For a FlexVol volume, a FlexGroup volume, Consistency Group or a Bucket destination endpoint, the properties in this object can be specified either from the source or the destination cluster. For an SVM destination endpoint, the properties in this object can be specified from the destination cluster only. This object is not supported for non ONTAP endpoints. While protecting a S3 Bucket, the optional "size" property can be used to create ONTAP S3 Bucket destination endpoint of the specified size.</destination-svm-name:></destination-svm-name:>
bucket_retention
bucket_retention
enabled
boolean
Optional property to create the destination endpoint when establishing a SnapMirror relationship. It is assumed to be "false" if no other property is set and assumed to be "true" if any other property is set.
size
integer
Optional property to specify the size of destination endpoint in bytes. This property is applicable only to ONTAP S3 Bucket endpoints. The minimum size for S3 bucket is 80MB and maximum size is 64TB. If not specified, system will create destination with default size of 800GB.
  • Introduced in: 9.10
  • x-nullable: true
snapshot_locking_enabled
boolean
Optional property to create the destination endpoint with snapshot locking enabled when establishing a SnapMirror relationship. This property is applicable to FlexVol volumes and FlexGroup volumes.
storage_service
storage_service
tiering
tiering
cluster
_links
_links
name
string
uuid
string
name
string
The name of the volume.
luns
Optional property for a SnapMirror endpoint. Specifies the list of source LUNs and optionally list of destination LUNs during SnapMirror Consistency Group LUN restore operation.
_links
_links
name
string
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
uuid
string
The unique identifier of the LUN.
svm
_links
_links
name
string
uuid
string
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster
cluster
array[consistency_group_volumes]
This property specifies the list of FlexVol volumes or LUNs of a Consistency Group. Optional on the ASA r2 platform. Mandatory for all other platforms.
luns
luns
path
string
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
  • example: svm1:volume1
  • x-nullable: true
svm
svm
policy
Basic policy information of the relationship.
_links
_links
name
string
Name of the SnapMirror policy.
type
string
uuid
string
Unique identifier of the SnapMirror policy.
snapmirror_source_endpoint
Source endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster
cluster
luns
luns
path
string
  • x-nullable: true
svm
svm
svmdr_volumes
name
string
transfer
Basic information on the current transfer or the last transfer if there is no active transfer at the time of the request.
_links
_links
bytes_transferred
integer
Total bytes transferred in the current or last successful transfer.
end_time
string
End time of the last transfer.
last_updated_time
string
Last updated time of the bytes transferred in the current transfer.
state
string
total_duration
string
Elapsed time to transfer all snapshots for the last successful transfer.
type
string
Specifies the operation type of the current transfer on the relationship. The initialize transfer occurs when the relationship state changes from "uninitialized" to "snapmirrored" or "in_sync". The update transfer occurs when snapshots are being transferred from the source endpoint to the destination endpoint as part of a scheduled or manual update. The resync transfer occurs when the relationship state changes from "broken_off" to "snapmirrored" or "in_sync". The restore transfer occurs when a snapshot is being restored from a destination endpoint to another endpoint.
uuid
string
Transfer UUID. This property is applicable only for active transfers.
transfer_schedule
Schedule used to update asynchronous relationships. This "transfer_schedule" overrides the "transfer_schedule" set on the SnapMirror relationship's policy. To remove the "transfer_schedule", set its value to null (no-quotes). Only cron schedules are supported for SnapMirror.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_error
SnapMirror error
arguments
array[string]
Arguments present in the error message encountered.
code
string
Error code
message
string
Error message
SnapMirror relationship information. The SnapMirror relationship can be either "async" or "sync" based on the type of SnapMirror policy associated with the relationship. The source and destination endpoints of a SnapMirror relationship must be of the same type, for example, if the source endpoint is a FlexVol volume then the destination endpoint must be a FlexVol volume. The SnapMirror policy type "async" can be used when the SnapMirror relationship has FlexVol volume or FlexGroup volume or SVM as the endpoint. The SnapMirror policy type "sync" can be used when the SnapMirror relationship has FlexVol volume as the endpoint. The SnapMirror policy type "sync" with "sync_type" as "automated_failover" can be used when the SnapMirror relationship has Consistency Group as the endpoint.
_links
_links
backoff_level
string
Specifies the SnapMirror backoff level due to Client Ops for FlexVol SnapMirror relationships.
  • readOnly: 1
destination
snapmirror_endpoint
exported_snapshot
string
Snapshot exported to clients on destination.
group_type
string
Specifies the group type of the top level SnapMirror relationship. The volume relationships are shown as none, the SVMDR relationships are shown as svm_dr, the Consistency Group relationships are shown as consistency_group, and the FlexGroup volume relationships are shown as flexgroup.
healthy
boolean
Is the relationship healthy?
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type. This "identity_preservation" overrides the "identity_preservation" set on the SnapMirror relationship's policy.
io_serving_copy
string
Specifies the sites serving I/O for the SnapMirror active sync relationship.
lag_time
string
Time since the exported snapshot was created.
string
Specifies the compression ratio achieved for the data sent over the wire with network compression enabled for the last successful transfer.
last_transfer_type
string
Specifies the operation type of the last transfer that occurred on the relationship. The initialize transfer occurs when the relationship state changes from uninitialized to snapmirrored or in_sync. The update transfer occurs when the snapshots are transferred from the source endpoint to the destination endpoint as part of scheduled or manual update. The resync transfer occurs when the relationship state changes from broken_off to snapmirrored or in_sync. The restore transfer occurs when the snapshot is restored from a destination endpoint to another endpoint.
string
Specifies the Master Bias Activated Site for the SnapMirror active sync relationship.
policy
policy
preferred_site
string
Specifies the Primary Site of the SnapMirror active sync relationship.
preserve
boolean
Set to true on resync to preserve snapshots on the destination that are newer than the latest common snapshot. This property is applicable only for relationships with FlexVol volume or FlexGroup volume endpoints and when the PATCH state is being changed to "snapmirrored".
quick_resync
boolean
Set to true to reduce resync time by not preserving storage efficiency. This property is applicable only for relationships with FlexVol volume endpoints and SVMDR relationships when the PATCH state is being changed to "snapmirrored".
recover_after_break
boolean
Set to true to recover from a failed SnapMirror break operation on a FlexGroup volume relationship. This restores all destination FlexGroup constituent volumes to the latest snapshot, and any writes to the read-write constituents are lost. This property is applicable only for SnapMirror relationships with FlexGroup volume endpoints and when the PATCH state is being changed to "broken_off".
restore
boolean
Set to true to create a relationship for restore. To trigger restore-transfer, use transfers POST on the restore relationship. SnapMirror relationships with the policy type "async" can be restored. SnapMirror relationships with the policy type "sync" cannot be restored.
restore_to_snapshot
string
Specifies the snapshot to restore to on the destination during the break operation. This property is applicable only for SnapMirror relationships with FlexVol volume endpoints and when the PATCH state is being changed to "broken_off".
source
state
string
State of the relationship. To initialize the relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". To break the relationship, PATCH the state to "broken_off" for relationships with a policy of type "async" or "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" cannot be "broken_off". To resync the relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" can be in "broken_off" state due to a failed attempt of SnapMirror failover. To pause the relationship, suspending further transfers, PATCH the state to "paused" for relationships with a policy of type "async" or "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" cannot be "paused". To resume transfers for a paused relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". The entries "in_sync", "out_of_sync", "synchronizing", "expanding", and "shrinking" are only applicable to relationships with a policy of type "sync". A PATCH call on the state change only triggers the transition to the specified state. You must poll on the "state", "healthy" and "unhealthy_reason" properties using a GET request to determine if the transition is successful. To automatically initialize the relationship when specifying "create_destination" property, set the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync".
svmdr_volumes
array[svmdr_volumes]
Specifies the list of constituent FlexVol volumes and FlexGroup volumes for an SVM DR SnapMirror relationship. FlexGroup constituents are not considered.
throttle
integer
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited.
integer
Cumulative bytes transferred for the relationship.
string
Indicates the cumulative duration of all transfers since the last aggregate relocation, takeover/giveback, or metrocluster switchover/switchback involving the node that hosts the relationship.
transfer
transfer
transfer_schedule
transfer_schedule
unhealthy_reason
array[snapmirror_error]
Reason the relationship is not healthy. It is a concatenation of up to four levels of error messages.
uuid
string
Unique identifier of the SnapMirror relationship.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
