REST API reference
Retrieve a collection of plexes for an aggregate
GET /storage/aggregates/{aggregate.uuid}/plexes
Introduced In: 9.6
Retrieves the collection of plexes for the specified aggregate.
  • storage aggregate plex show
aggregate.uuid
string
path
True
Aggregate UUID
online
boolean
query
False
Filter by online
name
string
query
False
Filter by name
state
string
query
False
Filter by state
resync.percent
integer
query
False
Filter by resync.percent
resync.active
boolean
query
False
Filter by resync.active
resync.level
string
query
False
Filter by resync.level
pool
string
query
False
Filter by pool
raid_groups.raid_type
string
query
False
Filter by raid_groups.raid_type
  • Introduced in: 9.9
raid_groups.reconstruct.active
boolean
query
False
Filter by raid_groups.reconstruct.active
  • Introduced in: 9.7
raid_groups.reconstruct.percent
integer
query
False
Filter by raid_groups.reconstruct.percent
raid_groups.disks.disk.name
string
query
False
Filter by raid_groups.disks.disk.name
raid_groups.disks.usable_size
integer
query
False
Filter by raid_groups.disks.usable_size
raid_groups.disks.type
string
query
False
Filter by raid_groups.disks.type
raid_groups.disks.state
string
query
False
Filter by raid_groups.disks.state
raid_groups.disks.position
string
query
False
Filter by raid_groups.disks.position
raid_groups.cache_tier
boolean
query
False
Filter by raid_groups.cache_tier
raid_groups.recomputing_parity.percent
integer
query
False
Filter by raid_groups.recomputing_parity.percent
raid_groups.recomputing_parity.active
boolean
query
False
Filter by raid_groups.recomputing_parity.active
raid_groups.name
string
query
False
Filter by raid_groups.name
raid_groups.degraded
boolean
query
False
Filter by raid_groups.degraded
aggregate.name
string
query
False
Filter by aggregate.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[plex]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "message": "entry doesn't exist"
  "num_records": 1,
  "records": [
      "aggregate": {
        "name": "aggr1",
      "name": "plex0",
      "pool": "string",
      "raid_groups": [
          "disks": [
              "disk": {
                "name": "1.0.1"
              "position": "string",
              "state": "string",
              "type": "ssd",
              "usable_size": 947912704
          "name": "rg0",
          "raid_type": "raid_dp",
          "recomputing_parity": {
            "percent": 10
          "reconstruct": {
            "percent": 10
      "resync": {
        "level": "string",
        "percent": 10
      "state": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
self
aggregate
Aggregate
_links
_links
name
string
uuid
string
disk
Disk
_links
_links
name
string
raid_group_disk
disk
disk
Disk
position
string
The position of the disk within the RAID group.
state
string
The state of the disk within the RAID group.
type
string
Disk interface type
usable_size
integer
Size in bytes that is usable by the aggregate.
recomputing_parity
active
boolean
RAID group is recomputing parity
percent
integer
Recomputing parity percentage
reconstruct
active
boolean
One or more disks in this RAID group are being reconstructed.
percent
integer
Reconstruct percentage
raid_group
cache_tier
boolean
RAID group is a cache tier
degraded
boolean
RAID group is degraded. A RAID group is degraded when at least one disk from that group has failed or is offline.
disks
array[raid_group_disk]
name
string
RAID group name
raid_type
string
RAID type of the raid group.
recomputing_parity
recomputing_parity
reconstruct
reconstruct
resync
active
boolean
Plex is being resynchronized to its mirrored plex
level
string
Plex resyncing level
percent
integer
Plex resyncing percentage
plex
aggregate
aggregate
Aggregate
name
string
Plex name
online
boolean
Plex is online
pool
string
SyncMirror pool assignment
raid_groups
array[raid_group]
resync
resync
state
string
Plex state
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
