REST API reference
Retrieve connection status between a cache and origin volume
GET /storage/flexcache/connection-status/{node}/{svm}/{local_fg_msid}/{remote_svm_uuid}/{remote_vol_const_msid}
Introduced In: 9.18
Retrieves connection status between a cache and origin volume.
  • volume flexcache connection-status show
node
string
path
True
Node Name
svm
string
path
True
SVM Name
local_fg_msid
integer
path
True
Local FG MSID
remote_svm_uuid
string
path
True
Remote SVM UUID
integer
path
True
Remote Constituent MSID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
conn_state
string
Connection Status between the Flexcache and Origin volumes.
last_update_time
string
Last update time of the connection status.
local_fg_msid
integer
The local volume's Master Set ID.
node
string
Name of the node.
remote_cluster
string
Remote cluster.
remote_endpoint
string
Remote endpoint type.
remote_svm
string
Remote volume SVM.
remote_svm_uuid
string
Remote SVM UUID.
integer
Remote volume's Master Set ID.
remote_volume
string
Remote Volume name.
svm
string
Volume SVM.
svm_uuid
string
Local SVM UUID.
volume
string
Local Volume name.
      "href": "/api/resourcelink"
  "conn_state": "string",
  "last_update_time": "2018-06-04 19:00:00 +0000",
  "local_fg_msid": 0,
  "node": "string",
  "remote_cluster": "string",
  "remote_endpoint": "string",
  "remote_svm": "string",
  "remote_svm_uuid": "string",
  "remote_vol_const_msid": 0,
  "remote_volume": "string",
  "svm": "string",
  "svm_uuid": "string",
  "volume": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
