REST API reference
Update the cluster network security configuration
PATCH /security/cluster-network
Introduced In: 9.18
Updates the cluster network security configuration.
Optional properties
  • 'enabled' - Indicates whether cluster network security is enabled.
  • 'mode' - The cluster network security mode.
  • 'security cluster-network modify'
Request Body
Name Type Description
enabled
boolean
mode
string
status
string
The status of the cluster network security configuration.
Example request
  "mode": "string",
  "status": "ENABLING | DISABLING | READY"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
70320128
Modifying the cluster network security configuration requires an effective cluster version of ONTAP 9.18.1 or later.
70320131
Cluster network security does not support MetroCluster configurations.
70320132
The cluster has an out of quorum node, wait until all nodes are in quorum before modifying the cluster network security configuration.
string
security_cluster_network
Manages the cluster network security configuration.
enabled
boolean
mode
string
status
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
